Author Topic: ABS/TC HELP PLEASE  (Read 6705 times)
  • Online Online
Re: ABS/TC HELP PLEASE
« Reply #15 on: 25 May 2011, 20:24:39 »
Does your speedo still work?
it did when it last happend, what does its mean if it does or dosnt work
speedo takes its signal from the ABS, so if it's fubar'd your speedo doesn't get a signal hence no speedo.
whitebullet
  • stoke
« Reply #16 on: 25 May 2011, 20:32:36 »
ive just been out and drove it around the block and the lights were on and the speedo didnt work, i then pulled up and the lights went out and the speedo worked but then it the lights came on again and speedo stopped, does the power steering fluid have anything to do with as i have just checked all the fluids and it seem way too low
HALFORDS TRADE CARD HOLDER
VAUXHALL  TRADE CARD HOLDER
« Reply #17 on: 25 May 2011, 20:43:30 »
ABS ECU for certain ... about £130 to have it mended by BBA REman ... :)
whitebullet
  • stoke
« Reply #18 on: 25 May 2011, 20:46:28 »
£130 i dont have, looks like it will be sold or stripped :o >:(
« Last Edit: 25 May 2011, 20:47:16 by whitebullet »
  • Online Online
« Reply #19 on: 25 May 2011, 20:52:38 »
.. does the power steering fluid have anything to do with  ....
Yes, the power steering is speed sensitive and gets its signal from the ABS  ;)
You could always try A N Other ECU, but it has to be from a similar car. But you are taking a risk that the 'new' ECU isn't already goosed or nearly goosed.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #20 on: 25 May 2011, 20:53:02 »
Get one from a Breaker (plenty on here) and 2 hours work, you'll have a fully functioning car.  ::)
whitebullet
  • stoke
« Reply #21 on: 25 May 2011, 20:57:31 »
would that cause the lights to come on though
« Last Edit: 25 May 2011, 20:58:00 by whitebullet »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #22 on: 25 May 2011, 20:59:27 »
No.
Andy was saying that the Speed Sensitive part of the Power Steering is linked to the Speed Signal.
Low fluid wont cause your issues.
It's the ECU!
« Reply #23 on: 25 May 2011, 21:00:44 »
You`ve been advised of the fault. Bite the bullet & get it repaired or get shot of it. One of the joys of buying from E-bay
whitebullet
  • stoke
« Reply #24 on: 25 May 2011, 21:00:53 »
No.
It's the ECU!
ok thanks,
i'll see what i can sort out, but keep your eyes peeled for a few parts
« Reply #25 on: 25 May 2011, 21:01:52 »
No.
It's the ECU!
ok thanks,
Meaning :question :question
whitebullet
  • stoke
« Reply #26 on: 25 May 2011, 21:02:03 »
yes daddy ;D
whitebullet
  • stoke
« Reply #27 on: 25 May 2011, 21:03:12 »
No.
It's the ECU!
ok thanks,
meaning i might break it
« Reply #28 on: 25 May 2011, 21:05:00 »
Was looking at your car on the bay but when the "owner" refused to answer every question I asked, decided it was a bit of a lemon
« Reply #29 on: 25 May 2011, 21:06:17 »
No.
It's the ECU!
ok thanks,
250 posts to sell anything on here ::)
« Last Edit: 25 May 2011, 21:07:06 by RobG »
Pages: 1 [2] 3 4  All   Go Up
