Author Topic: SAI pipes removal...  (Read 1046 times)
lou
  • Romford
  • Always expect the unexpected
« on: 10 August 2011, 11:10:57 »
I am thinking of removing my SAI gubbins for easier access for servicing. How can I blank of the pipes from the manifold as they can not be removed. Has anyone undertaken this project?
Re: SAI pipes removal...
« Reply #1 on: 10 August 2011, 11:19:13 »
You could probably shove a 15mm plumbing stop-end into the end of the rubber pipe and tighten the jubilee clip onto it?
I_want_an_Omega
« Reply #2 on: 11 August 2011, 22:15:52 »
That's exactly what I did, except I soldered a short length of 15mm pipe on so the end stop is just proud of the rubber coupler and there is a good inch of copper pipe down inside the rubber. Works a treat
