Author Topic: Omega s reg 2.5 v6 runnin problem  (Read 2447 times)
Re: Omega s reg 2.5 v6 runnin problem
« Reply #15 on: 08 August 2011, 21:42:59 »
For a misfire under load you need to check as said:
Spark plugs
HT leads (condition, and not oil contaminated)
DIS Pack
Note you have swapped a lot of components - therefore you need to check if you are a pot down and the reason why.
First check all plugs sparking ok - remove a plug with HT lead still connected and earth out body of plug (use jump start lead connected to metal plug body and to earth on battery) and crank - if no spark you have found duff pot.
Next need to check if ignition or mechanical - do a compression test on duff cylinder and compare results to others - if compressions all reasonally high and roughly equal  mechanically ok - problem ignition or fuel.
If good sparks on all cylinders and compressions ok suspect fuel (injectors)
HTH :y
Cleetus
« Reply #16 on: 10 August 2011, 13:43:24 »
Gettin a 19 on paper clip trick would this b anythin to do with it?
« Reply #17 on: 10 August 2011, 13:49:16 »
Yep, crank sensor
Cleetus
« Reply #18 on: 10 August 2011, 16:21:22 »
Even no it always revs on spot fine just shite under load?
Cleetus
« Reply #19 on: 12 August 2011, 18:32:58 »
Crank sensor now changed no surgin any more just flat as a witches tit top end revs on the spot to about 5000 then fluffs out and dont like also there is a loud hissing noise from engine/exhaust? Any suggestions
