Author Topic: Omega s reg 2.5 v6 runnin problem  (Read 2452 times)
Cleetus
« on: 02 August 2011, 22:08:34 »
Hi my omega started playin up today it runs smooth and revs fine until you put under load and becomes very jolty and sluggish as if runnin out of fuel any suggestions before it starts costing loads thankyou
Re: Omega s reg 2.5 v6 runnin problem
« Reply #1 on: 02 August 2011, 22:10:41 »
check the maint guide index for the paperclip test (see my sig)
and check for fault codes, and post em here.
Also hows the service history?
air and fuel filters recent?
spark plugs? (leads and dis ever been changed)?
« Reply #2 on: 02 August 2011, 22:12:43 »
Sounds like a misfire under load.
Need to check:
HT leads (condition, and not oil contaminated)
DIS Pack
Spark plugs
In that order :y
Where are you located?
MutantCav
  • Gainsborough
« Reply #3 on: 02 August 2011, 22:19:44 »
As said...misfire under load...
First thing I would check would be to pull out the leads one by one and look for oil in the spark plug wells...if there is, and chances are there is...your cam covers are leaking...chance are this is due to the breather system never having been cleaned out and blocking...
Also check to see if the rubber on the leads is perishing...
Other potential cause is the dispack at the other end of the leads as the casing can crack over time (especially if rain water is getting through the join in your scuttle)
But as said, regardles of the reasons it will almost certainly be due to either the spark plugs, the leads and/or the dispack :y
« Last Edit: 02 August 2011, 22:20:18 by ShieldOfSteel »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #4 on: 03 August 2011, 00:04:18 »
or camcover gaskets    :P :P :y
Cleetus
« Reply #5 on: 03 August 2011, 18:43:30 »
Tried the paper clip trick jus flashes once then twice and continues doin this?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 03 August 2011, 18:48:27 »
12  is just start of sequence,means you have no codes stored if thats all it does
other rides
Cleetus
« Reply #7 on: 03 August 2011, 18:55:25 »
So its pckin up no faults then?
MutantCav
  • Gainsborough
« Reply #8 on: 03 August 2011, 19:28:12 »
That's right...but quite normal very often with misfires...
MutantCav
  • Gainsborough
« Reply #9 on: 03 August 2011, 19:30:25 »
As covered before that :y Cam cover would be the most likely reason for the plugs/leads/dispack failing but it will be the plugs/leads/dispack itself that has failed hence the misfire...obviously though the cause needs to be cured too and not just the symptoms :y
« Last Edit: 03 August 2011, 19:31:28 by ShieldOfSteel »
Cleetus
« Reply #10 on: 03 August 2011, 20:38:24 »
Cheers lads all plug sockets are dry so will try the dis first as cheapest solution and hopefully cure it. Is it a mission to change dont look to clever??
« Reply #11 on: 03 August 2011, 20:49:03 »
..... Is it a mission to change dont look to clever??
Lets just say it's awkward  ::) ::)
Remove the wipers & scuttle to give you a bit more access, I think some remove the plenum although not strictly necessary. It's bolted to its bracket with Torx headed bolts but you can get away with a normal 6 sided socket (8mm IIRC)
Apply plasters to hands when finished.  ;D ;D ;)
Cleetus
« Reply #12 on: 03 August 2011, 21:09:13 »
Ok cheers sounds like a nice job for my mate. Any one no the best/cheapest place to purchase one :-/
« Reply #13 on: 03 August 2011, 21:10:47 »
I would replace the fuel filter before doing any of these other things, unless you know its been changed quite recently. ;)
Cleetus
« Reply #14 on: 08 August 2011, 19:49:05 »
Right fuel filter done coil pack done plugs and leads done still no better still funny fuel pump maybe? Cheers
