Author Topic: 2.5 TD Stripped sump plug threads!  (Read 4270 times)
Agemo
  • Cleethorpes
  • Insignia
Re: 2.5 TD Stripped sump plug threads!
« Reply #15 on: 11 August 2011, 10:22:49 »
OK I have converted a wheel stud into a sump plug, and it seemed a decent job. I now have transport, so will go looking for Helicoil kits. I wasn't sure about the idea, but now I am convinced they are an improvement, not a bodge. Thanks for the tips gents.
« Last Edit: 11 August 2011, 13:21:56 by Agemo »
« Reply #16 on: 11 August 2011, 17:05:54 »
You can use my kit if you want, think it even has a spare sump plug with it.
Agemo
  • Cleethorpes
  • Insignia
« Reply #17 on: 11 August 2011, 17:21:20 »
Very kind offer there Mark, but I have too much respect for other peoples tools, I will find a set at a reasonable price. Where are you by the way?
« Reply #18 on: 11 August 2011, 17:22:30 »
Nottingham
Its not a huge item so could be posted and as its an alloy sump its not like you will wear it out  :y
« Reply #20 on: 11 August 2011, 20:17:52 »
12.5mm will be fine in alloy to as when you use a 12mm the tap just removes the extra 0.5mm.
I  ave used a spark plug helicoil (as its a more useful kit to have!) and a peugeot sump plug (pretty sure its a pug one)
Yes, it is one of the pug one.  Can't remember which, but seem to recall it being a 12x1.25 thread, and dealer found one easily.
Not point not helicoiling, as those BMW sumps are made of monkey metal, and just retapping larger WILL eventually strip again.
Agemo
  • Cleethorpes
  • Insignia
« Reply #21 on: 11 August 2011, 20:30:54 »
Thanks Mark, but I have seen them on ebay & they are not that expensive. This one is the right size:- http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260816553220&ssPageName=STRK:MEWAX:IT#ht_3448wt_1139   Hardly worth you posting & me returning it. (I would replace your actual coils) Thanks for the offer though.
If I use the above kit, I will keep the original sump plug. (M12x1.5)
Good point TB, nothing to gain by just tapping a bigger hole, Helicoil makes it stronger, sounds ideal. I was concerned about the swarf, but as said, it will be falling out of the hole, plus I can flush the sump with some cheapo oil.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #22 on: 11 August 2011, 23:12:53 »
This is what I now use for changing the engine oil Glen :y
Click:  http://a2zshop.org.uk/shop/article_a829/DRAINAGE-OIL-FLUID-EXTRACTION-EXTRACTOR-SYPHON-PUMP-AM-TECH.html?pse=apq
Worth every penny! ;) ;) ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #23 on: 11 August 2011, 23:29:49 »
Nice piece of kit, I like the idea, does it handle HOT oil OK?  ::)
Seth
« Reply #24 on: 11 August 2011, 23:43:49 »
Absolutely perfectly Glen! :y
And it extracts all the oil, bar a cup-full (literally) from a TD! ;)
« Last Edit: 11 August 2011, 23:44:44 by Reliance505 »
Agemo
  • Cleethorpes
  • Insignia
« Reply #25 on: 12 August 2011, 09:45:11 »
Brilliant, however that last cupful is the most important bit to get out. I suppose we never really know exactly how much sludge we are leaving in though.
I must look into it.  :y
« Last Edit: 12 August 2011, 09:45:35 by Agemo »
« Reply #26 on: 12 August 2011, 15:24:30 »
When MDTM helicoiled my tractor (stripped thread, retapped larger, stripped again (and this was the 2nd sump I had that was stripped)), I put on a quick drain sump plug.
This hung a tad low, and I caught it at around 80mph, as the car regained contact with the tarmac on a spirited drive.  The sump plug itself was never found, but the helicoil was undamaged.  Slapped in a spare spark plug (same thread), filled with oil, drove home ::)
Agemo
  • Cleethorpes
  • Insignia
« Reply #27 on: 12 August 2011, 20:31:12 »
Hell! You were very very lucky! Never heard of the "quick drain plug" but I did think of fitting a valve instead of the plug. Decided against it because it would hang down a little. Can't believe the Helicoild wasn't stripped out! Spare spark plug - Brilliant, man after my own heart.
EDIT - Just looked up what these quick drains are, yes I was thinking of a valve like that, but didn't want it protruding downwards, for obvious reasons! I did think of an M&F elbow which could then have a valve fitted horizontally. Will got Helicoil soon.
« Last Edit: 12 August 2011, 20:38:32 by Agemo »
Seth
« Reply #28 on: 12 August 2011, 23:04:24 »
Ours gets an oil/filter change every 2500 miles anyway, so I ain't bothered by this. ;)
Both TD sumps that I've looked inside have been spotless and completely sludge free. :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #29 on: 12 August 2011, 23:11:39 »
Brilliant, 2,500 miles, no problem then.
Nice to hear about your clean sumps, if mine was easy to remove, I would love to have a look. I suppose the suction pipe will be plastic, so you can "hoover" the bottom a bit anyway!
