Author Topic: 2.5 TD Stripped sump plug threads!  (Read 4304 times)
Agemo
  • Cleethorpes
  • Insignia
« on: 10 August 2011, 15:23:35 »
As title, took out the sump plug, felt OK (if a little tight for the first few turns) When I screwed it back in, it felt OK, never even got a socket on it, it just started to go finger-tight,  then went a bit more, then finger-tight again.  Was turning forever, no warning at all. I changed the oil myself last time & everything went fine, although I think I used a torque wrench to nip it up (for the first time ever!). I have looked at the plug, which looks a little worn, so I am assuming it's the sump insert that has the weakest threads.
I suppose my options are:-
1/ Helicoil, - no experience of these, plus I haven't any taps etc.
2/ Change sump for a new/second hand one, - I quite like this idea, I would know the inside of my sump wasn't an inch thick with sludge
3/ Bigger sump plug, - Is it possible to just replace the plug, with something "one size bigger?"
I would like to know if there are any other options, and I may be after a replacement TD sump.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 2.5 TD Stripped sump plug threads!
« Reply #1 on: 10 August 2011, 15:44:50 »
Experienced the exact same occurrence on mine Glen >:(
I found that the cast boss was actually split - not the threads being stripped.
There's no threaded insert in the sump, so examine the 'boss' carefully.
If it's okay, simply heli-coil it and keep your fingers crossed.
If you're looking at changing the sump, (as I had to), you'll need to remove the sub-frame, after supporting the lump, which is not an easy task.
You should also, ideally, have a full geometry set-up/check - unless you can replicate the sub-frame's exact location.
Hope the heli-coil route works for you mate, and I now use a syphon-type extractor thingy!
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 10 August 2011, 15:50:58 »
OK mate, thanks for that. I will nip out and inspect the boss. Didn't realise a sump swap was such a pain!  :-/
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 10 August 2011, 16:02:43 »
OK, had a look, the boss looks fine. I think it's Helicoil time, will have to wait for someone to give me a lift to Halfrauds or somewhere.
The plug doesn't look bad, perhaps not perfect but usable, although I may as well get another.
I know, crap picture, but they do show the thread isn't that bad.  I didn't realise the was no insert, just a threaded hole in a bit of Ally!
« Last Edit: 10 August 2011, 16:19:05 by Agemo »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 10 August 2011, 17:54:21 »
Had the same problem, drilled it with a 12mm drill, and fitted an M14 x 1.5 plug. That was about 6 oil changes ago, no further problems, but I pump out now anyway, so no need to remove the plug. Incidentally I used a 12mm drill rather than the recommended 12.5mm for this size plug, (then tapped it) and it was the ideal size in ally, probably 12.5mm would be OK in steel.
HTH  :y
Edit: Forgot to say I tapped it to the above size.
« Last Edit: 10 August 2011, 18:23:38 by ci643215 »
« Reply #5 on: 10 August 2011, 18:00:54 »
12.5mm will be fine in alloy to as when you use a 12mm the tap just removes the extra 0.5mm.
I  ave used a spark plug helicoil (as its a more useful kit to have!) and a peugeot sump plug (pretty sure its a pug one)
Shackeng
  • Ramsbury
« Reply #6 on: 10 August 2011, 18:24:22 »
Agreed. :y :y :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #7 on: 10 August 2011, 19:56:59 »
OK now I have seen the job, I don't fancy changing sumps!  It looks worse than I thought, not sure about how to go about it yet, but if there is no option . . .
Helicoil, again I am not happy with the sounds of this, doing the job in situ, swarf in the sump, never even seen a Helicoil kit. I would need a bit of advice. Hmmm . . .
I do like the idea of getting the sump off, nice to know the inside is clean, but what a job!
Agemo
  • Cleethorpes
  • Insignia
« Reply #8 on: 10 August 2011, 20:50:06 »
STOP PRESS. I noticed that the thread is an M12 x 1.5, which is the same a wheel stud. I tried a brand new stud, and although I haven't had a spanner in, I think it is a decent fit (not perfect but better). The sump plug feels more of a round thread than the Vee thread on the wheel stud. This gives me some breathing space, I could fit it the wheel stud with Loctite, so I have transport. I can then acquire a new sump, or get a Helicoil kit, or a replacement sump, and do the job at my leisure.
Another option is to get a sump plug one size bigger, or would this be too big? Any thoughts on this gents?
« Last Edit: 10 August 2011, 21:16:24 by Agemo »
Shackeng
  • Ramsbury
« Reply #9 on: 10 August 2011, 22:06:02 »
See my post above ref drilling and tapping, took very little time and fixed it. :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #10 on: 10 August 2011, 22:26:15 »
Thanks Shack, yes I read that, just that I have not used one so am a little apprehensive. I will see what I can buy tomorrow, hopefully a tap, Helicoil, and bigger sump plug.
It's a shame nobody markets a tapered plug, sounds ideal for a lot of people. Why are they all parallel threads?
« Last Edit: 10 August 2011, 22:28:55 by Agemo »
« Reply #11 on: 10 August 2011, 22:28:16 »
Because a tapered plug on alloy would be even more likely to strip threads.
Do remember that with a Helicoil you dont need a larger size sump plug and you do get a much stronger thread
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 10 August 2011, 22:30:30 »
Right, fair comment.  Oh! I didn't realise that, good point. I like to keep things standard. Thanks.
Seth
« Reply #13 on: 11 August 2011, 01:46:11 »
I also used a 12mm drill (before realising the actual casting was split!), and found it really straightforward Glen.
Just drill gently and slowly, and in a few seconds you're done. :y
Swarf will tend to emerge downwards along the drill-bit flutes anyway - so don't worry over it! ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #14 on: 11 August 2011, 08:43:58 »
Yes thanks, I have had a think & decided Helicoil is my best option. I can run a pint or two of oil through the plug hole, and as you said, most tends to go away from the direction of drilling. I will put the car back on the road and go Helicoil shopping.
 :y  Thanks for the help.
Page created in 0.012 seconds with 14 queries.
