Author Topic: Revs in ECO mode  (Read 1323 times)
lou
  • Romford
  • Always expect the unexpected
Revs in ECO mode
« on: 13 August 2011, 22:57:04 »
Having recently had waterpump changed, i noticed that the revs with aircon off is the same as with it on. +/- 600rpm and not the usual 500 rpm. Aircon does work and switches off with eco on with dip in revs but then returns to 600 rpm. All fans work correctlly and compressor clutch plate stops turning when switch off . Any ideas what this could be caused by?
« Last Edit: 14 August 2011, 09:41:54 by jstzjm »
Re: Revs in ECO mode
« Reply #1 on: 14 August 2011, 11:57:22 »
Air leaks? Some pillock messed with the butterfly stop?
lou
  • Romford
« Reply #2 on: 14 August 2011, 15:47:10 »
Good point as this is a replacement Throttle body which has been polished. Incidently how do you set up the stop screw?
« Last Edit: 14 August 2011, 15:47:44 by jstzjm »
« Reply #3 on: 14 August 2011, 16:49:59 »
Set it so the butterflies FULLY close.  The electronics deal with allowing the correct amount of air in at idle.
lou
  • Romford
« Reply #4 on: 14 August 2011, 17:56:53 »
Thanks for advice...will have a look
