Author Topic: ABS question  (Read 987 times)
furrymunkey
  • N.E Scotland
ABS question
« on: 14 August 2011, 17:49:34 »
In an earlier post I asked for help about lack of speedo. Well after digging about I pulled off the wiring plug going into the top of the ABS and it had quite a lot of corrosion. I managed to clean it up but noticed that one of the pins were actually broken, which would explain a lot.
Question is......I've attached a pic of the part I will need and I'm hoping and praying....would it be possible to replace this part without removing the whole unit?...just wondered as it is right on the top
http://s653.photobucket.com/albums/uu260/tigermit/?action=view&current=abs.jpg
It's on a 97 2.0
Here's a link to a unit identical to mine
http://www.ebay.co.uk/itm/VAUXHALL-OMEGA-INC-V6-ABS-UNIT-PUMP-ECU-94-03-/110605130134
« Last Edit: 14 August 2011, 18:28:42 by furrymunkey »
Varche
  • middle of Andalucia
    • Golf Estate
Re: ABS question
« Reply #1 on: 14 August 2011, 19:39:48 »
Can't help with the answer about what you have to replace but pre 97 cars had three channel brakes I believe and then the minifacelift cars of late 97 onwards had 4 channel brakes that suffered from failed ECUS a lot. So I am fairly certain the "Body" that the ECU mounts on will be different.
Do you know for certain that the part in the EBay ad is identical to yours?
furrymunkey
  • N.E Scotland
Re: ABS question
« Reply #2 on: 14 August 2011, 19:42:26 »
Picture wise it's identical. Part number may be different but is identical to the one in my car
