Author Topic: Cambelt sorted.....but I have aproblem.  (Read 3036 times)
« on: 15 August 2011, 16:46:10 »
Genuine Vauxhall cambelt, tensioners, and water pump now fitted. refilled with anti-freeze all in £330 :y :y :y :y.But :'( :'( :'(........apparently I have oil in the coolant. The Vx mechanic showed me oil sludge in the expansion tank.
They tell me the car needs a new oil cooler (leaking)to sort the problem before it gets worse. They quoted four to five hours labour plus parts £568.44....Shit.
Opinions please gentlemen. :-/ :-/ :-/
Re: Cambelt sorted.....but I have aproblem.
« Reply #1 on: 15 August 2011, 16:50:09 »
Well the diagnosis is right, sounds like oil cooler.
Parts wise looking at £150 ish, its actually a very straight forward task, even I did one  :o :o  ;D
5 hours is a bit much for a garage, plenum off & fuel injection manifold off.... 30 mins?
Old cooler out new one in, 1 hour? 30 mins to put back together?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 15 August 2011, 16:55:18 »
Are you coming to Newent?  If so and if you can limp it there I or someone else could change it out for you.
5 hours is what a complete novice would take to do the job.  When I did one and the oil cooler pipes had seized on the union bolts near the oil filter I had to hacksaw them off and use my favourite tool to get them out then find a way to thread the replacement pipes in which was a pig.  I think that took a total of 6 hours.
« Reply #3 on: 15 August 2011, 17:00:39 »
Is it a total goo or is it just a few spots?
If the latter it may have been a failure in the dim adn distant past and there is still some traces of oil in the system
« Reply #4 on: 15 August 2011, 17:21:34 »
Thanks for the offer Guffer. :y. I doubt I can make  Newent. I really must come to one of these OOF meets sooner or later.
« Reply #5 on: 15 August 2011, 17:32:39 »
The expansion tank was empty when he showed me Mark.There appeared to be a build up of sludge/slime on the inside of it.
« Reply #6 on: 15 August 2011, 17:35:58 »
Could indicate a previous failure, as its been driven now, take the cap off, see if there is any oil floating on top.
If you can post some photos of what you see  :y
martin42
« Reply #7 on: 15 August 2011, 18:16:58 »
easiest thing to do is remove coolant tank and give it a good clean out and then see what happens,hth  :y
« Reply #8 on: 15 August 2011, 18:17:28 »
She is still at Vx. I pick her up tomorrow.The job was  half finished when I  looked. I could clearly see the new belt and it's shiny new tensioner's though.
Seems like a good idea to monitor the situation for a while when I get her back before I part with any money. I check the coolant level regularly and I don't ever recall seeing any oil floating in it.
« Last Edit: 15 August 2011, 18:22:12 by optimist »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #9 on: 15 August 2011, 18:41:58 »
You better come and do some for me Tunnie....... What about the time it takes to clear the water system, which is the biggest pain? How long to do that? Or is that in your 1hr 30 minutes?  ::)
« Reply #10 on: 15 August 2011, 20:00:01 »
I must have flushed Project TB1 about 50 times over 2 weeks after its oil cooler failed.
OK, probably a better job than a dealer or garage would do, but apparently I'm anal ::)
« Reply #11 on: 15 August 2011, 21:05:26 »
Not quoting for that, just replacement work done  ;)
« Reply #12 on: 15 August 2011, 21:07:38 »
You better come and do some for me Tunnie....... What about the time it takes to clear the water system, which is the biggest pain? How long to do that? Or is that in your 1hr 30 minutes::)
Also 30 mins, plus 1 hour, plus 30 mins = 2 hours.
But then again, Stoke is on a different time zone  ;D ;D
« Reply #13 on: 16 August 2011, 08:29:22 »
To be honest I think 2 hours is a bit of a push (unless you bend the pipes)
MutantCav
  • Gainsborough
« Reply #14 on: 16 August 2011, 08:34:22 »
But 5 hours is rather excessive if not including flushing...certainly something on the list of things I can do and for well under £550 notes even including the cost of a set of crowsfoot spanners!! :y
« Last Edit: 16 August 2011, 08:39:26 by ShieldOfSteel »
