Author Topic: Various multiram questions.  (Read 885 times)
CHRISKG
  • NORTH WEST
    • 2000 3.0 MV6 Estate
« on: 17 August 2011, 14:42:03 »
Just learning my way around the v6 engine bay and though i'd check if my multiram system was working.
It isn't.
1st thing I noticed was the vac pipe connection to the actuator on the rear solenoid has snapped off.
What is the part number for this item?  The solenoid that is.
I hooked up a digi manometer to the pipe from the vac tank to test the vacuum.  It did start to slowly create a vacuum at idle.
Any idea what kind of figure this vac should be or how quickly it should be created?
Cheers
Chris
Re: Various multiram questions.
« Reply #1 on: 17 August 2011, 15:17:03 »
It isn't.
Cheers
Chris
Got one here, or you can use the one from the SAI :y
CHRISKG
  • NORTH WEST
« Reply #2 on: 17 August 2011, 17:26:16 »
Good tip.  I'll give that a go.
