Author Topic: Low Washer Fluid.  (Read 2794 times)
amba
  • Medway towns
    • German V6
Low Washer Fluid.
« on: 19 August 2011, 13:37:20 »
Guys .
Despite the screen washer bottle being full and not leaking from below,on turning ignition key messsage appears that " Washer Fluid Level" is low.
Any pointers as to where abouts is the sensor and how to get access to it.
Re: Low Washer Fluid.
« Reply #1 on: 19 August 2011, 14:04:45 »
Bottom of reservoir near centre, push fit
amba
  • Medway towns
    • German V6
« Reply #2 on: 19 August 2011, 14:12:10 »
Thanks RobG.
Poor old "girl" is starting to show her age..bits keep failing...I know how she feels.
« Reply #3 on: 19 August 2011, 22:37:48 »
Same happened to me, a 30 second fix once you get a new part..... :y :y
« Reply #4 on: 19 August 2011, 22:39:24 »
...........got some more here if OP needs ;)
amba
  • Medway towns
    • German V6
« Reply #5 on: 20 August 2011, 07:49:04 »
Thanks guys for info.
Found it at filler end of bottle...access was simple with foglight and bumper grille removed.
Took the old one out and gave it a clean and refitted and so far problem seems to have been cured...fingers crossed.
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
« Reply #6 on: 05 February 2013, 17:14:15 »
Hi I've got this prob on my fl looks like washer bottle is. In front of the rad is it just a case of pulling old one out and putting new in and are these still available from dealer
    • 530D M Sport, 330i Coupe
« Reply #7 on: 05 February 2013, 17:38:29 »
Yep... just make sure the washer fluid level is below the level of the sensor when you pull the sensor out.  ;)
« Reply #8 on: 05 February 2013, 17:48:35 »
Dealer price might be a bit of a shock  :-\ I would advise to get one from RobG.
« Reply #9 on: 05 February 2013, 17:49:06 »
Got some here :y
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
« Reply #10 on: 05 February 2013, 18:22:49 »
Ok rob how much and how I get one thanks
« Reply #11 on: 05 February 2013, 19:38:02 »
PM sent
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
« Reply #12 on: 05 February 2013, 20:32:39 »
