Author Topic: catalytic converter failure - o2 sensor fail?  (Read 1049 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 18 August 2011, 09:21:01 »
if your catalytic converter failed would you get an error code from the o2 sensor? i dont have a fault, and im hoping its not the cat, but i have a rattle coming from that area. with a bit of luck it will be loose heatshield or something.
« Last Edit: 18 August 2011, 09:21:52 by ilovemyelite »
PM with your requests.
Re: catalytic converter failure - o2 sensor fail?
« Reply #1 on: 18 August 2011, 09:28:08 »
Not necessarily.
Hopefully it's just a heat shield and not the internals starting to rattle, although I've seen them with rattly internals and still passing the emissions tests OK :y :y
humbucker
  • Cambridgeshire
« Reply #2 on: 20 August 2011, 08:30:38 »
Ah ok cheers Paul.
