Author Topic: wipers  (Read 3058 times)
Bob G
  • Gloucester
Re: wipers
« Reply #15 on: 19 August 2011, 20:14:36 »
Wel went to the triangle relay box and think I have fond the problem, no relay!!!! fitted one and it all seesm to work but wipers will need adjusting as they park in the vertical, hope it is a simple adjustment and not anything else.
Thanks to all who replied.
Re: wipers
« Reply #16 on: 19 August 2011, 21:15:07 »
Ah! Now were getting somewhere. ;) If you remove the whole wiper assembly, be careful of the paint on the top of your driver's wing, you'll see an arm fixed to the taper/splined motor spindle. Slacken the M8 nut (13mm spanner) and move the arm back to between the marks on the ally casting ie >      <
Refit wiper assembly.  :y :y
Bob G
  • Gloucester
Re: wipers
« Reply #17 on: 19 August 2011, 21:58:17 »
Rob why would they be so far out? do you think that the asy might have been removed and not obthered to be set up correctly.
Re: wipers
« Reply #18 on: 19 August 2011, 22:03:34 »
More like the wipers were frozen to the screen, wipers left switched on and stopped halfway across the screen when the engine was stopped.  ;) ;)
Bob G
  • Gloucester
Re: wipers
« Reply #19 on: 20 August 2011, 18:26:33 »
Well at last sorted, but what a battle, they were so far out the set up was miles out, adjusted from the wiper motor and alls well, so guess someone had a problem and whipped the relay out to make life easy.
Thanks for all contributions
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: wipers
« Reply #20 on: 20 August 2011, 18:47:22 »
Glad you are all sorted Bob :y
Just chilling in the sun. I wish back in the rain like everybody else
