Author Topic: wipers  (Read 3056 times)
Bob G
  • Gloucester
wipers
« on: 18 August 2011, 20:20:49 »
Have a problem with the wipers, I have normal and fast, but no park and no intermitent, any suggestions please
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: wipers
« Reply #1 on: 18 August 2011, 21:36:06 »
could be faulty wiper motor
or
wiper relay.
if it only does it on intermittent then ide guess its the motor itself.had a similar problem on a mk3 astra and a new motor cured it..
Re: wipers
« Reply #2 on: 18 August 2011, 21:44:53 »
or
wiper relay.
I'd disagree, if the wipers work on slow & fast but not intermittent, then I'd go for A N Other relay ......... easier & quicker to swap too.  ;) ;)
Bob G
  • Gloucester
Re: wipers
« Reply #3 on: 18 August 2011, 23:06:27 »
or
wiper relay.
Andy think I wil run with relay at the moment, only have the Haynes manual at the moment which mentions relays but not which for which.  I assume thaat we are looking at the ones in the drop down section by the driver.  Going to a dealer tommorow to pick some bits up so could get a relay then.
Re: wipers
« Reply #4 on: 18 August 2011, 23:22:25 »
or
wiper relay.
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
This shows relay locations, I can't find the wiper relay for a 2.0  :-/ but it does show it as K8 for the 2/5/3.0 .......... I'd imagine them both to be similar. Try swapping with A N Other cos I'd expect a new relay to be a bit expensive as a test.
Re: wipers
« Reply #5 on: 18 August 2011, 23:26:44 »
or
wiper relay.
For the 2.0 & 2.2 also. Tall yellow one
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: wipers
« Reply #6 on: 18 August 2011, 23:31:30 »
Defo the relay i had the same fault on mine when i bought it
changed the motor and still the same a new relay sorted it out :y
Just chilling in the sun. I wish back in the rain like everybody else
Bob G
  • Gloucester
Re: wipers
« Reply #7 on: 18 August 2011, 23:53:50 »
Thanks one and all, will post result as soon as sorted      or    not  [smiley=cry.gif]
Re: wipers
« Reply #8 on: 19 August 2011, 00:22:28 »
If you were local Bob, could have collected one from me :(
Bob G
  • Gloucester
Re: wipers
« Reply #9 on: 19 August 2011, 09:46:48 »
Hi Rob
Always the case, we are near but not that near, lets hope the scrappy has a good one available today.
« Last Edit: 19 August 2011, 09:47:11 by chieftain900 »
Bob G
  • Gloucester
Re: wipers
« Reply #10 on: 19 August 2011, 18:24:25 »
Slightly confused now, got the relay from a breaker but it seemed to be attached to its own relay holder attched to the wiper stalk, I droped the panel down to see if there was relay there and no relay.  two location marked with I think fron window and rear window with a wiper blade on them, the relay does not seem to fit.  If it is at end of stalk according to Haynes to remove the shroud, there are two screws that can only be accessed once steering wheel is removed.  A bit over the top but is it correct and where does the relay go.  helpppppppppppp
Re: wipers
« Reply #11 on: 19 August 2011, 18:34:11 »
The relay is in the triangular box by the battery. Tall yellow one
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: wipers
« Reply #12 on: 19 August 2011, 18:50:32 »
The tall yellow one - pic courtesy of PhilRich:
[/quote]
I feel like a military academy. Bits of me keep passing out.
Re: wipers
« Reply #13 on: 19 August 2011, 18:57:02 »
as per - Engine Bay Relay Box layout http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
« Last Edit: 19 August 2011, 18:59:53 by Andy_B »
Bob G
  • Gloucester
Re: wipers
« Reply #14 on: 19 August 2011, 18:59:18 »
Thanks for that, very hard when you still have Scorpio running around your head  [smiley=2vrolijk_08.gif]
