Author Topic: Instrument illumination ?  (Read 2637 times)
« on: 20 August 2011, 20:43:18 »
As it is starting to get get dark a little earlier these days I switched the lights on to travel to the local shop......( That's a local shop for local people ..... ;D ;D ;D)
 The speedo lights up as does the fuel gauge. However, there is no illumination whatsoever for the temperature gauge, and the rev counter is only illuminated from 4,000-7,000 RPM.
Please don't tell me I have to spend hours ripping the instrument panel apart just to replace a crappy bulb (or two)  that has blown.... ;)
Re: Instrument illumination ?
« Reply #1 on: 20 August 2011, 20:44:24 »
20 minutes tops to take out, replace bulbs & re-fit
« Reply #2 on: 20 August 2011, 20:46:09 »
How/where?.....does it come apart Rob?
« Reply #3 on: 20 August 2011, 20:46:54 »
When you get around to ripping out removing the instrument housing .... replace ALL the bulbs not just the blown ones....
Law of sod says that one of the older ones will blow within a week .. I actually believe that the disturbance of the panel and/or differing resistance values of the new bulbs in parallel causes the old ones to blow..... whatever the reason .. it happens everytime !!!!
  • Auckland
    • Mazda MPV
« Reply #4 on: 20 August 2011, 20:53:25 »
« Last Edit: 20 August 2011, 20:56:23 by andyh »
cleggy
« Reply #5 on: 20 August 2011, 21:07:27 »
The left hand side of my panel would fail to light but a thump on the top of the dash cured it :y :y
« Reply #6 on: 20 August 2011, 21:08:22 »
Thanks Andy.......and the video is excellent. I can see exactly what needs doing now..... :y :y :y
alexw80
  • Bognor Regis
    • P reg Omega 2.0 CDX
« Reply #7 on: 20 August 2011, 21:44:04 »
Just out of interest, as mine tend to need a thump to get working sometimes, before I venture into taking it apart to replace the bulbs, does anyone know what bulbs are needed?
« Reply #8 on: 20 August 2011, 21:46:50 »
.. does anyone know what bulbs are needed?
waits with baited breath, I replaced all mine a few months ago, but I suspect that the bulbs supplied by Vauxhall are a higher 'wattage' than the originals  :-/ :-/ :-/
« Reply #9 on: 20 August 2011, 21:48:33 »
these :
http://www.autobulbsdirect.co.uk/504-3W-CAR-BULBS//
just slot into your existing 'bases'
« Reply #10 on: 20 August 2011, 21:51:45 »
and personally I'd do the MID as well while its out - law of the sod and all that...
with 4 of these
http://www.autobulbsdirect.co.uk/R509TGR-Dashboard-Bulbs-12V-2W-PCB-Light-Green-Base.html
chances are you are running on less than 4 of those anyway, most people dont notice until the last one goes!
« Reply #11 on: 20 August 2011, 21:53:44 »
these :
Thanks Mr Jimbob. I was wondering which bulbs were required. This type look familiar, I'll take a look in the garage......I may strike lucky. :y
« Reply #12 on: 20 August 2011, 21:54:53 »
these :
same size and shape as 'sidelight' lamps....but different wattage (2 or 3 w, not 5w)
« Reply #13 on: 20 August 2011, 21:56:38 »
Try this one, never did get round to replacing, must do before the winter..... ::) ::) ::)
http://www.omegaowners.com/forum/YaBB.pl?num=1278959381
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« Reply #14 on: 20 August 2011, 22:40:17 »
Wattage is 2 watts. Had to do mine. What a farce!!  and the dimmer switch does'nt! :-?
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
