Author Topic: Headlamp wobbly not adjuster  (Read 1487 times)
Martin_1962
« on: 20 August 2011, 15:36:33 »
W&D and polished the RHS headlamp today.
While checking it over I found the insides loose.
Not the adjuster but the inner side at the top, there is a white thing connected to a rod to the front. The inside part is broken off.
Any easy repair?
Or replacement headlamp time?
Re: Headlamp wobbly not adjuster
« Reply #1 on: 20 August 2011, 16:14:55 »
Any easy repair?
That`s where the adjuster is Martin :(
Martin_1962
« Reply #2 on: 20 August 2011, 17:45:26 »
Manual adjuster not the motor
« Reply #3 on: 20 August 2011, 18:33:03 »
:-? :question
Martin_1962
« Reply #4 on: 20 August 2011, 19:59:22 »
One with the metal rod from the front, motor is at other end of the light
« Reply #5 on: 20 August 2011, 20:03:13 »
All part of the adjuster mechanism Martin
Martin_1962
« Reply #6 on: 20 August 2011, 20:17:01 »
New lamp then?
« Reply #7 on: 20 August 2011, 20:58:08 »
New lamp then?
have you looked at the adjuster fitting guide? It might give you a pointer before you split your headlight.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1271424451
Martin_1962
« Reply #8 on: 20 August 2011, 21:00:11 »
New lamp then?
It is the white one on the right its left - black plastic thing is broken on it
« Last Edit: 20 August 2011, 21:00:34 by Martin_1962 »
« Reply #9 on: 20 August 2011, 21:01:52 »
New lamp then?
That`s the original fit adjuster
Martin_1962
« Reply #10 on: 20 August 2011, 21:34:08 »
New lamp then?
Main beam hole.
the motor is near the dip
Martin_1962
« Reply #11 on: 20 August 2011, 21:38:22 »
And I think it may be part of the reflector
Martin_1962
« Reply #12 on: 20 August 2011, 21:40:07 »
And also the top not the bottom
« Reply #13 on: 20 August 2011, 21:52:09 »
Main beam hole, arrowed is the adjuster. This what you mean Martin. That`s the only thing that`ll make the reflector loose.
Martin_1962
« Reply #14 on: 20 August 2011, 23:26:00 »
I'll whip it out tomorrow and take a picture
