Author Topic: 3.0 V6 suspension struts for 2.5 V6  (Read 1887 times)
Anthony in Madrid
  • Valencia, Spain
  • It's there...Go get it!
    • 1994 2.5 V6 170 BHP
« on: 17 August 2011, 12:25:11 »
Hi guys how ya diddlin today?
Got a question.....Can the rear suspension struts (with springs) from an 3.0 V6 fit my 96' 2.5 V6????
Would it make any difference to handling/ride?
Your answers as usual are always appreciated :y
Best regards
Ant
« Last Edit: 17 August 2011, 12:34:40 by aschneider1965 »
Still learning...Be nice!
2woody
  • Northumberland
Re: 3.0 V6 suspension struts for 2.5 V6
« Reply #1 on: 18 August 2011, 09:08:56 »
they're the same, PROVIDED
both cars are saloons, or both are estates
and either both have self-levelling or neither have self levelling
Anthony in Madrid
  • Valencia, Spain
« Reply #2 on: 18 August 2011, 09:43:19 »
Hi Woody
Thanks for the answer. But....how do I know If they are self levelling or not....& about the handling? Will it improve?
Regards
Anthony :y
Both cars are saloons, or both are estates
twiglet
  • Norwich, Norfolk
« Reply #3 on: 18 August 2011, 09:47:01 »
Your car is a CD, so it will not have self levelling suspension.  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #4 on: 18 August 2011, 10:27:44 »
No struts in the rear, springs are separate from shocks  :-/  :y
Anthony in Madrid
  • Valencia, Spain
« Reply #5 on: 19 August 2011, 11:33:07 »
So if I wanted to lower my Omega 25-30cms then what's the best process?
« Reply #6 on: 20 August 2011, 07:26:00 »
erm take the wheels off  ;D
guess you mean 'mm' not 'cm'
Anthony in Madrid
  • Valencia, Spain
« Reply #7 on: 20 August 2011, 08:33:44 »
Yes ...hahahaha mms!!
But I mean to lower a car what exactly is the process?
Cheers
Ant :y
« Reply #8 on: 20 August 2011, 09:54:47 »
 ;D ;D
the only way to lower a miggy 30 cms is to dig the ground..  ;D :y
Anthony, you need lowered springs.. even they are not cheap.. better approach is all springs and shocks.. will be really pricey..handling will be better , but comfort will be disturbed..
« Last Edit: 20 August 2011, 09:57:56 by cem_devecioglu »
Anthony in Madrid
  • Valencia, Spain
« Reply #9 on: 20 August 2011, 10:47:12 »
Hey CEM how ya doin?
So my whole point is to make my car look lower ..... not drastically but noticeable and fit some new 17inch Wheels but i just don't know what the lowering process is. Remember I'm new to this.
Can I do the procedure myself?
Do I need to buy new Dampers+Springs+Struts or will I just need to change the springs.
If I fit 17" Wheels will this make the car look lower or can I still or need to lower the car.
I kind of want this look for my Baby!!!
Best Regards
Ant :Y
« Last Edit: 20 August 2011, 11:09:27 by aschneider1965 »
« Reply #10 on: 20 August 2011, 11:03:57 »
Best Regards
Ant :Y
Thanks I'm fine Anthony.. And I hope you are fine too :y
If you are experienced in mechanic jobs on cars and have some equipment , you can.. otherwise no I'm afraid..
I would suggest 17 wheels+tires ..this will shorten the gap between the tires and body.. also will change the handling and brakes..(depending on the budget)
 however if I were you thinking with my previous experiences on omega ,I would use the car for few months and try to understand if it has some problems or not..An aged car is never the same as a brand new one.. I think a healthy car is more important..so I would spend my money/budget firstly for  some parts renewal like brakes,discs, geometry, old sensors and leaking gaskets, oil changes (engine+gearbox+differential)..after you are confident about the car totally then I would go for cosmetic changes..
« Last Edit: 20 August 2011, 11:09:09 by cem_devecioglu »
Anthony in Madrid
  • Valencia, Spain
« Reply #11 on: 21 August 2011, 10:29:01 »
Cem! True what you say. All I can say is "Damn this excitement!"  ;D
But you are right. I will cruise around in the new Omega for a while. Maybe see how she passes the forthcoming winter then make the changes that are needed.
Best regards
Anthony :y
Best Regards
Ant :Y
« Reply #12 on: 21 August 2011, 10:51:14 »
Best regards
Anthony :y
Best Regards
Ant :Y
 :y :y :y
