Author Topic: V6 Radiator Drain plug.  (Read 2809 times)
« on: 20 August 2011, 15:47:01 »
Where is it located Please?. I presume it does have one. :y
Re: V6 Radiator Drain plug.
« Reply #1 on: 20 August 2011, 15:58:50 »
passenger side, right at the bottom, its a red tap  :y
« Reply #2 on: 20 August 2011, 15:59:35 »
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 20 August 2011, 15:59:47 »
I was always under the impression that there wasn't one but when I removed the rad (replacement fitted 7 years ago at a VX garage) there was one.
Little half inch gnurled head located on passenger side at the bottom of rad on a UK car.
« Reply #4 on: 20 August 2011, 16:11:05 »
Thanks Mr Tunnie I'll take another look. If I remove this will it empty the cooling system of all 9 litres?
« Reply #5 on: 20 August 2011, 16:17:16 »
Yep...Found it. I was looking too far forward. :y
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #6 on: 20 August 2011, 17:02:46 »
No - a few litres will be left in the engine block, matrix and other nooks and crannies.  I guess I got around five out of mine.
I feel like a military academy. Bits of me keep passing out.
« Reply #7 on: 20 August 2011, 17:07:37 »
it will only dump whats in the rad and expansion tank, water will remain in the engine block and heater matrix, you will only dump around half of your coolant.
I'm not sure if it would be a good idea to fill it back up with fresh water, run for just a minute or so (with heaters on full to flush heater matrix) - Then dump the coolant again.
Anyone got any thoughts?  :-/
I assume its going to be stood for a week before the great one replaces your oil cooler?
« Reply #8 on: 20 August 2011, 17:19:11 »
New ones are now black !!
« Reply #9 on: 20 August 2011, 17:20:41 »
This is more or less what Mark suggested  I should do. :y Drain and refill with water each time I use it.
« Last Edit: 20 August 2011, 17:23:18 by optimist »
I_want_an_Omega
« Reply #10 on: 20 August 2011, 17:34:37 »
It might seem obvious, but you will need to remove the header tank lid for air to displace the water. If you dont then not much will come out. This is a useful feature to avoid your arm getting too wet. Open the plug, then remove the cap.
Also, the drain plug will come out totally - but has a feature so that you can fully unscrew it and just let it dangle there. Pull it out if needs be - but dont forget where you put it.
Dont forget that the coolant isn't nice stuff - it's toxic, so dont pour it down the drain.
I took mine down the local tip and they were happy to pour it in with the waste oil "we separate it all out later mate".
Good luck  :y
« Reply #11 on: 20 August 2011, 17:40:56 »
Good luck  :y
The car is on the grass. Does coolant act as a"lawn feed?".... ::) ::) ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 20 August 2011, 20:23:12 »
It keeps the slugs away, that's why you never get slug bites in your Rad!  ::)
« Reply #13 on: 20 August 2011, 23:37:01 »
I'm on fire if the great one suggested that too  :o  ;D
« Reply #14 on: 21 August 2011, 11:34:50 »
Such a modest unassuming title..... ::) ::) ::) ;D ;D ;D
