Author Topic: omega 2.2 cd  (Read 2028 times)
macey
  • Sandhurst Berkshire
omega 2.2 cd
« on: 15 August 2011, 18:32:51 »
Hi There I have owned my omega 2.2 for 4yrs no trouble but just recently trouble starting it with a cough and a blow but when it gets going it runs as normal and when i stop and start it again 1 hour later its fine just that first operation over night. It's 2.2 petrol and done 98000 miles any suggestions please
Re: omega 2.2 cd
« Reply #1 on: 15 August 2011, 18:35:28 »
Is the EML on
macey
Re: omega 2.2 cd
« Reply #2 on: 15 August 2011, 18:37:29 »
yes
the alarming man
  • medway kent
    • disco V8
Re: omega 2.2 cd
« Reply #3 on: 15 August 2011, 18:39:41 »
think it is time too read some codes do you have access to obd reader ??? :y
« Last Edit: 15 August 2011, 18:40:59 by the_alarming_man »
macey
Re: omega 2.2 cd
« Reply #4 on: 15 August 2011, 18:42:12 »
sorry no
Re: omega 2.2 cd
« Reply #5 on: 15 August 2011, 18:42:42 »
Update your profile with location etc :y
macey
Re: omega 2.2 cd
« Reply #6 on: 15 August 2011, 18:50:34 »
RobG im new to this and i cant seem to edit my profile my location is sandhurst berkshire if that helps
the alarming man
  • medway kent
    • disco V8
Re: omega 2.2 cd
« Reply #7 on: 15 August 2011, 20:36:29 »
if you p.m kevin wood he as access to a tech 2 which can read your fault code and in  turn tell you whats wrong  :y
Re: omega 2.2 cd
« Reply #8 on: 15 August 2011, 20:46:02 »
As per other thread, what light "spanner" or "engine" :question
Gpz John
  • Bolton
Re: omega 2.2 cd
« Reply #9 on: 15 August 2011, 20:53:25 »
Hello
My 2.2 petrol auto Has the same problem .
It will show spanner sometime then next time engine symbol
and it seems to be missing on start up but runs ok  after that .
I am in Bolton area if any one know someone to check the codes.
Thanks in advance
John
Gpz John
  • Bolton
Re: omega 2.2 cd
« Reply #10 on: 15 August 2011, 20:55:40 »
Sorry for jumping in on This thread :'(
But its identical probs as mine .
Must be the weather !!!
Re: omega 2.2 cd
« Reply #11 on: 16 August 2011, 00:43:32 »
You really need to get the codes read, I have had a problem recently which, through experience, I would have said was a cam sensor, as it happens I am just about to change my coil pack as have a misfire on cylinder 1............... :(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: omega 2.2 cd
« Reply #12 on: 16 August 2011, 07:02:36 »
Symptoms Point to the cam sensor, but you need to get the codes read.
As I've said before, if it is the cam sensor - only buy one from a Vx dealer, do NOT buy one from anywhere else, even if it's supposed to be 'genuine'.
I like red cars
moneyspider
Re: omega 2.2 cd
« Reply #13 on: 21 August 2011, 23:22:59 »
I had very similar symptoms, changed the cam sensor, and maf sensor, all is well, have to say, only had cam sensor on me fault reader, but picked up a maf sensor for under a tenner, yes under a tenner ;) and put it on, as changing the cam sensor I still had a lumpy tick over on a morning, get it checked though on a reader though, and make sure. OH by the way, noticed oil on the old cam sensor, so changed the cam cover gasket as well just to make sure. Good luck with it. :y
