Author Topic: Brake upgrade  (Read 3072 times)
F1 9LFG
  • nr Braintree, Essex
Brake upgrade
« on: 21 August 2011, 14:14:00 »
Hi all, did I once read something about GTO or something brakes being a straight swap for the omega brakes? calipers and disks? front and/or rears?
Seems my front disks have warped, judder under braking is bad, pads are low so looks like disks and pads are needed so perfect time to swap if they do indeed fit.
Thanks  :y
Re: Brake upgrade
« Reply #1 on: 21 August 2011, 14:40:22 »
Thanks  :y
Just replace like for like, they're more than capable of stopping your car. Trade Club pads & discs are around £100, excellent value for money, & will take you no time at all to fit.  :y :y
F1 9LFG
Re: Brake upgrade
« Reply #2 on: 21 August 2011, 14:48:13 »
Thanks  :y
Ahh that would be far far too easy  ;D
Just upgraded to 17'' wheels and thought it'd look slightly better with bigger calipers, also I do a huge amount of motorway driving so an improvement in stopping power would also be a welcomed feeling
Cheers  :y
Re: Brake upgrade
« Reply #3 on: 21 August 2011, 14:52:15 »
Thanks  :y
Cheers  :y
They stop a 3.2  ;) so should easily stop a 2.6  ;) ;) :y
Re: Brake upgrade
« Reply #4 on: 21 August 2011, 14:59:28 »
Have a look on here mate - the guy that runs it is a member of OOF (same user name).  He did that upgrade on his Catera.
Re: Brake upgrade
« Reply #5 on: 21 August 2011, 16:05:32 »
Obviously, if its for styling, thats a different matter.  But for road use, the standard setup is more than adequate.  I'd only consider changing if it was for track use.
Concentrate on keeping them in good condition will give better results than anything where they have been neglected enough for the pads to get low, and the discs to deform.
F1 9LFG
Re: Brake upgrade
« Reply #6 on: 21 August 2011, 20:16:03 »
Partly styling, partly better braking, the larger the pad surface to the disk, the less effort required in braking, like wise with pistons, GTO has two,OEM has one.
I'd say my pads are two thirds of the way through their life, so not completely shot, lately I've had to hit the anchors a few times, now I have a judder under medimum braking so obviously warped rotas sadly.
« Last Edit: 21 August 2011, 20:17:44 by F1_9LFG »
F1 9LFG
Re: Brake upgrade
« Reply #7 on: 21 August 2011, 20:19:20 »
Thanks for that - that must have been what I saw a while ago, assuming the 'GTO' is the UK's Monaro?
If so I'm on the hunt for some monaro calipers!  :y
Re: Brake upgrade
« Reply #8 on: 21 August 2011, 20:47:07 »
and the rears?
Huge stopping power at the front with standard at the back is probably going to give a tendency for the back to want to lock up.  :-/ :-/ :-/
F1 9LFG
Re: Brake upgrade
« Reply #9 on: 21 August 2011, 21:34:38 »
and the rears?
Rears will remain standard, may swap to monaro calipers if they too are a straight swap though.
If i encounter the back stepping out then I will have to look into Bias valves (considering the ABS) but I can't imagine any problems cropping up as it's not like I'm sticking on a set of 8pot calipers with 350mm rotas.
Not sure about the omega but a massive percentage of braking at high speed is at the front of most cars anyhow.
« Last Edit: 21 August 2011, 21:36:01 by F1_9LFG »
Re: Brake upgrade
« Reply #10 on: 21 August 2011, 21:52:51 »
and the rears?
Not a lot of braking is from the rear, my pads lasted about 150k  ;D ;D
That said, putting new pads on the rear on the 3.0, it felt noticeable improvement.
Depends though, if that extra power is going to cause the TC to be used a lot more, which could cause pads to be eaten fast
Re: Brake upgrade
« Reply #11 on: 21 August 2011, 22:02:49 »
2/3rds of pads used puts them beyond their useful life IMHO.  Its not a competition how much you can get out of them.
Warped discs implies cheap, nasty pattern discs. I've not yet managed to warp GM ones, thus gone back to them from an experimentation with marginally cheaper, pattern ones.
Anyone who has been in my MV6 when I've been testing brakes will know the weak point is the tyre/tarmac interface.
As said, if its for styling alone, thats a different kettle of fish, but for actual performance, a well maintained GM standard setup will be far more satisfactory than less well maintained non standard ones.
Re: Brake upgrade
« Reply #12 on: 21 August 2011, 22:06:01 »
You don't know if they were changed before you got it ;). Also you lack TC, which hammers the rear pads ::)
Like the bike, if you had a proper bike, the rear brakes help provide stability, esp in bends, as well as braking capacity.  You have noticed this on your Mum's estate once you serviced the rears.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Brake upgrade
« Reply #13 on: 22 August 2011, 07:30:15 »
Mark changed my rear pads recently (genuine Vx), made a tremendous difference to the braking.
I like red cars
2woody
  • Northumberland
Re: Brake upgrade
« Reply #14 on: 22 August 2011, 09:35:27 »
I have a couple of GTOs - quite simply, their brakes are more weedy than a standard Omega. Avoid.
brake upgrades MUST be done on a "whole-car" basis. Imagine trying to explain to the judge how you have 150% bigger brakes on the front, but have not changed the rear at all.
Have you thought about pad coefficient of friction, piston diameter, brake effective radius, front-rear weight balance, brake factor, master cylinder size ? etc, etc, etc
