Author Topic: Spax lowering springs  (Read 1679 times)
rockayansky
« on: 20 August 2011, 19:38:46 »
I'd like peoples opinions please. I'm getting tired of sliding out my seat when going round roundabouts. I've seen spaz offer a set lowering car by 40mm. Would these be too stiff an spoil
The ride completely of the elite? If so would MV6 springs be a better opti
so comfortably numb
Re: Spax lowering springs
« Reply #1 on: 22 August 2011, 20:02:14 »
Does no one have an opinion on this then?
« Reply #2 on: 22 August 2011, 20:14:28 »
Obviously not ;D
IMHO, 40mm is too low, and would have to be unnecessarily stiff. One of the key advantages of RWD is you don't need to spring it so your fillings fall out :y
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 22 August 2011, 20:18:01 »
If your going to drop it by 40mm, change the shockers for ones with a shorter shaft or you will end up bouncing down the road.
A Mv6 setup is a nice compromise  :y
If you realy want to drop it that far, Eibach springs and Bilstien B4 / B6 shocks have been fitted by some on here with great results  :y
« Reply #4 on: 22 August 2011, 20:25:11 »
Although that's only on a 30mm drop ;)
so comfortably numb
« Reply #5 on: 22 August 2011, 20:29:16 »
No that's just it. I don't wana go that low. I just want to firm it up without wrecking the ride quality.  So would one of the atfer market sets be too stiff compared to the MV6's?
And can anyone vouch for the difference between elite and mv6 feel?
« Reply #6 on: 22 August 2011, 20:33:33 »
Irmscher Red springs, B4 shocks. Works well once settled in (but a little harsh to start with)
Unfortunately the Red springs are like rocking horse poo so Eibach are (apparently) the next best thing :y
« Reply #7 on: 22 August 2011, 20:35:04 »
dont.. 20 mm is more than enough..
else you will hit the cats, exhaust in every bump/hole and will have very harsh ride..
« Reply #8 on: 22 August 2011, 20:35:36 »
I have one of each, although my MV6 is also Irmscher sprung, GM shocked at the front and GM sprung/B4 shocked at rear.
The Elite is not to my liking - although the crappy Michelin tyres don't help - my MV6 is perfect IMHO.
Needless to say, I'm desperately trying to get hold of some Irmscher springs for Elite ::)
tigers_gonads
  • Online Online
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 22 August 2011, 20:37:47 »
Thats funny, swmbo always says i'm cr*p at estimating lengths  ;D ;D
Omega_Dan
« Reply #10 on: 22 August 2011, 22:22:21 »
Any spring offering a 30 to 40 mm Drop will offer somewhere in the region of 70 to 80 % of that due to heavy settling of original springs. I have lowered a few cars with 40mm springs and have got 30-35mm drop.
Again the MV6 setup is desirable :y
« Last Edit: 22 August 2011, 22:22:46 by Omega_Dan »
« Reply #11 on: 22 August 2011, 22:28:59 »
I was going to comment that although it says 30mm, I've measured one with a 30mm drop and it was more like 25mm lower than mine ::)
