Author Topic: removal of cats on a 2.6 v6  (Read 3241 times)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« on: 21 August 2011, 16:27:49 »
need to remove both cats as having to replace gearbox.
have managed to remove bolts that secure cats to centre exhaust system but i am struggling to remove nuts that secure cats to manifolds.
1) what size nuts are they  15mm  ???
2) what tools are needed as everything i have tried i cant seem to get enough purchase on them.
3) do cats need to be removed to remove gearbox ???
sorry its a bit long winded but any help would be grateful
Re: removal of cats on a 2.6 v6
« Reply #1 on: 21 August 2011, 16:34:05 »
16 or 17mm, couple of extensions, breaker bar or torque wrench for leverage, cats off
noel
  • frome somerset
« Reply #2 on: 21 August 2011, 16:43:15 »
tried a universal joint because very awkward to get at.
do the sockets need to be long reach ?? bit hard to see whats going on up there as i wear verifocal glasses and a pain in the arse when looking upwards  >:(
« Reply #3 on: 21 August 2011, 16:45:21 »
1)  16mm
2)  16mm socket, long extensions and breaker bar - try soaking in plusgas first  :y
3)  Fraid so mate
noel
  • frome somerset
« Reply #4 on: 21 August 2011, 16:50:41 »
had plus gas on them and in my mouth and eyes.
will have another go later  :y
noel
  • frome somerset
« Reply #5 on: 21 August 2011, 21:19:08 »
begining to wish i had never started this  >:(
« Reply #6 on: 21 August 2011, 21:21:28 »
Perseverance :y
noel
  • frome somerset
« Reply #7 on: 21 August 2011, 21:25:03 »
cant even get the 16mm socket to grip and a15mm seems to tight.
bit scared im going to cock this up. :-[
« Reply #8 on: 21 August 2011, 21:27:02 »
Ahhh the joys of owning a 4 pot, I can just reach in from the bonnet and access all exhaust manifold studs  :D
I would not be surprised if the nuts had been changed over the years, I remember working on a V6 which had 4 different sizes on one bank  :o  ;D ;D
noel
  • frome somerset
« Reply #9 on: 21 August 2011, 21:33:10 »
would be so bad if you could undo from inside the engine bay  but there is only a nut on cat side and none on manifold side. :(
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #10 on: 22 August 2011, 09:16:50 »
You need a deep 16mm socket, the normal ones just aren't deep enough.  The nuts may be a little corroded so you may have to tap the socket onto the nut slightly.  The larger spark plug sockets fit the task perfectly ::)
noel
  • frome somerset
« Reply #11 on: 22 August 2011, 11:02:43 »
just bought some more sockets so going to have another crack at it,pardon the pun  ;)
noel
  • frome somerset
« Reply #12 on: 22 August 2011, 13:18:38 »
right 3 nuts off but top nut passenger side is having none of it ( badly rounded now ).
is it possible to remove gear box with just one cat removed (drivers side removed ) ??? >:(
« Reply #13 on: 22 August 2011, 17:16:43 »
Never tried it mate - remember you need to remove/replace in a straight line, not at an angle.  Cannot recollect clearances.
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #14 on: 22 August 2011, 18:03:37 »
I think you are going to have to persevere. The reason? The o ring gasket between the end of the cat and the manifold will need replacing. I had to reuse mine pending getting new ones and one blew really badly.
If you have some old sockets whitworth or AF you might find something that you can "hammer on" by testing on a nut you have taken off already. More plus gas. Also watch out for falling sockets! I got one right on the bridge of my nose doing that job.
Two man job doing the gearbox but you know that.
Page created in 0.079 seconds with 16 queries.
