Author Topic: Crank Sensor failed within 15 months :-(  (Read 1306 times)
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
« on: 24 August 2011, 20:44:30 »
I have been getting the intermittent starting problem, I thought it was the fuel pressure regulator, but just read the codes on a friends cheapo "My Naff Code Reader" and it came up with
Total number of fault codes: 1
00019 - Incorrect RPM Signal
Not present
Only had it replaced last year too. :( anybody know the cost of these? very bad timing financially atm.
Are they readily available? or do I need to order?
« Last Edit: 24 August 2011, 21:04:20 by ratsalad »
John
Re: Crank Sensor failed with 15 months :-(
« Reply #1 on: 24 August 2011, 20:55:55 »
They have been known to fail when newish. Ring round VX dealers to find one which has one in stock.There are different types so make sure you get the correct one. ;)
Ratty
  • Coventry
« Reply #2 on: 24 August 2011, 21:02:07 »
Cheers Albs, I'll give the local dealer a ring tomorrow, even though they're not known for their service with a smile.  >:(
John
Re: Crank Sensor failed within 15 months :-(
« Reply #3 on: 24 August 2011, 21:50:37 »
I think they cost around £65. :y
Ratty
  • Coventry
« Reply #4 on: 24 August 2011, 21:58:19 »
Cheers, is that trade or retail? Daz helped me get the last one. I think that cost about 56 squid inc VAT. iirc it was over the 100 retail  :o
While I'm here what bolt holds it in, I don't wanna get under there and find I don't have the right socket, Lee (Welung666) fitted it for me back in May last year because due to health issues on my part, I couldn't get under there, still gonna struggle now but with the slightly warmer weather it'll be easier  :y
John
Ratty
  • Coventry
« Reply #5 on: 26 August 2011, 15:37:23 »
Not that anybody is really interested  :-/ but I got the Sensor today, £57.46 TC. Now just gotta wait for a dry spell to fit it  :y
John
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 26 August 2011, 15:51:23 »
Glad you got it, I think the socket needed is an e8 or e10 but you might get it off with an 8 mm or 10 mm socket
Ratty
  • Coventry
« Reply #7 on: 26 August 2011, 15:54:43 »
Ah ha, Thank you, was trying to work out what i needed the guide says a T8 which is a female bolt and it confused me a little (not hard to do under normal circumstances anyway  ;) )
John
