Author Topic: Retrofit OEM sunroof  (Read 3565 times)
grijander
« on: 25 August 2011, 19:28:59 »
Hi,
It's an old wish since I drove the Supermirafiori!!
Has anyone retrofitted it?
Do you know if roof on these cars have xtra reinforcements?
Can be used current roof panel?
thanks in advanced
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: Retrofit OEM sunroof
« Reply #1 on: 25 August 2011, 19:56:35 »
well there's a bizzare request,, seems like one hell of alotta work for not much return, if you fill in the hole in my roof you can have mine!!
Warning: Dates in Calendar are closer than they appear.
grijander
« Reply #2 on: 25 August 2011, 20:17:01 »
I made it before on 131 with a simple one(just up and down) and was quite easy!! :y
« Reply #3 on: 25 August 2011, 20:47:52 »
Nightmare, just buy another Omega with one already fitted. They are cheap enough!
twiglet
  • Norwich, Norfolk
« Reply #4 on: 25 August 2011, 21:30:14 »
Hi,
thanks in advanced
Never, ever, ever gonna happen!!
« Reply #5 on: 25 August 2011, 21:35:55 »
Hi,
thanks in advanced
Standard push up roof is easy to fit. "Nibbler" for the metal roof and oscillating small blade circular saw for the roof re-bars
« Reply #6 on: 25 August 2011, 21:39:31 »
Yep - big saw. big tube of mastic. Piece of p1ss. what could possibly go wrong ?  :y :D
« Last Edit: 25 August 2011, 21:39:56 by albitz »
« Reply #7 on: 25 August 2011, 21:54:50 »
Yep. Used to retrofit them in new Toyota Previa`s straight off the boat at Portbury dock
« Reply #8 on: 25 August 2011, 22:00:16 »
Silcone sealant can cover a multitude of sins. :y ;D
grijander
« Reply #9 on: 25 August 2011, 22:36:55 »
« Reply #10 on: 25 August 2011, 23:35:29 »
its a normal application here.. they use generally webasto..
http://www.eliftuning.com/Sunroof-Acilir-Tavan/137
but you may have heart attack with the prices ;D
« Reply #11 on: 26 August 2011, 00:37:04 »
Your link is not working.... :(
If I was going to retro fit a Webasto I would want the old vinyl one that folds back over almost the whole roof... :) :)
Something like this
http://www.ebay.co.uk/itm/MGB-SUNROOF-WEBASTO-/230640216720?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b33a6a90
grijander
« Reply #12 on: 26 August 2011, 08:06:34 »
Well, I was thinking in something cheaper like http://www.ebay.co.uk/itm/VAUXHALL-OPEL-OMEGA-SUNROOF-GLASS-SUN-ROOF-ASSEMBLY-/380100730136?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item587fc4dd18
Although this type may require tack welding? :-/
« Reply #13 on: 26 August 2011, 08:16:11 »
It's a lot of work for very little return IMO. I can probably count on one hand the number of times I have opened an Omega sunroof in the last 3 years ;) I tend to use the climate all the time anyway and open the window if I want some air from outside :y
If you do go down that route you'll need a new roof lining too ;)
« Reply #14 on: 26 August 2011, 09:38:47 »
I was delighted to find an Omega without a sunroof when I bought mine. Can't abide the things. A load of extra weight in the worst possible location (high up in the car).
If it doesn't leak, it'll develop a mind of its' own and start opening itself or, at the least, the paint will flake off the surround and it'll look tatty.
Don't bother - IMHO. ;)
Page created in 0.023 seconds with 16 queries.
