Author Topic: starting problems  (Read 1255 times)
mike d
  • castleford yorkshire
starting problems
« on: 27 August 2011, 01:45:30 »
just had my glowplugs and leakoff pipes replaced,now its a pig to start when hot 2.5td
cheers
mike
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: starting problems
« Reply #1 on: 27 August 2011, 14:08:20 »
haye you checked all the wire plugs to make sure they have good contact??
Solar charger fitted.
If not Broke dont fix it..
mike d
« Reply #2 on: 27 August 2011, 15:55:39 »
starts first time when cold,the only other thing the garage changed was leak off pipes.
where do they end up?does injection pump sit under battery?reason i ask there seems to be fluid on pump.
if leak off pipes end up there and are leaking could that be the problem???
cheers
mike
freecall666
« Reply #3 on: 27 August 2011, 20:30:35 »
can you check if it is fuel thats on the pump,,, if is would not use engine until the leak is found, if the problem started after the garage so called fixed i would get them to fix the problem they have made, you should not have to pay for them to fix it if do then inform trading standards.....
