Author Topic: Changing Power Steering Fluid  (Read 1103 times)
« on: 27 August 2011, 22:32:49 »
My steering fluid has a slight burnt smell to it, the level is also looking quite low. (barley makes it onto the stick when closed)
In my entire ownership i've never touched the PAS fluid! Whats the best way?
Pop that man pipe off the bottom of the header tank?
I don't see a guide, I can make one  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Changing Power Steering Fluid
« Reply #1 on: 27 August 2011, 22:36:45 »
I normally pop the return pipe off the reservoir and plug the hole then extend the return pipe with a length of hose into a bucket and start engine,add fresh fluid until it runs clean into the bucket,re-connect pipe and re-fill system.That should get rid of most of the old stuff :y
« Last Edit: 27 August 2011, 22:37:09 by henryd123 »
other rides
« Reply #2 on: 27 August 2011, 22:41:05 »
What he said ^  :y
« Reply #3 on: 27 August 2011, 22:44:55 »
Cheers Henry, big pipe at the bottom being the return pipe? Does the extended hose need to be pressurised or just a "loose" extension?
Thanks  :y
« Reply #4 on: 27 August 2011, 22:45:21 »
Oh whats a good source for fluid too?  :)
henryd
  • west cornwall
« Reply #5 on: 27 August 2011, 22:52:50 »
Thanks  :y
Whichever pipe that does not go to the pas pump is the return pipe,fluid wise dexron II plenty good enough.Not a lot of pressure into bucket at idle speed but plenty of flow :-?
other rides
« Reply #6 on: 27 August 2011, 22:54:32 »
Cheers  :y
henryd
  • west cornwall
« Reply #7 on: 27 August 2011, 22:56:40 »
Don't do it on your nice tarmac or paved driveway in case of slight spillage ::)
other rides
« Reply #8 on: 27 August 2011, 22:58:16 »
Hummm, might nudge it onto the grass  ;D
« Reply #9 on: 28 August 2011, 11:10:36 »
will damage the grass, very poisonous..
« Last Edit: 28 August 2011, 11:11:34 by cem_devecioglu »
