Author Topic: Omega 2.2 CD Reg 52 Fault Diagnosis Help  (Read 2318 times)
macey
  • Sandhurst Berkshire
« on: 17 August 2011, 22:35:08 »
Hi I am looking for anyone who lives near me who owns a fault diagnosis machine to tell me what codes are displaying as i have trouble starting the Omega. I live in sandhurst and im willing to travel to sought this frustrating problem out. and of coarse cover the cost of your time. Location once again sandhurst Berkshire GU47 0QN Many Thanx Macey
« Last Edit: 17 August 2011, 22:40:05 by macey »
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Omega 2.2 CD Reg 52 Fault Diagnosis Help
« Reply #1 on: 18 August 2011, 01:02:23 »
In the meantime you could always do the pedal trick to see how many errors/faults you have and then someone with a diagnostic can have a thorough look!
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #2 on: 18 August 2011, 06:33:54 »
Pedal trick doesn't work on a 2.2, I'm afraid.
I like red cars
« Reply #3 on: 18 August 2011, 07:16:24 »
Drop a PM to Kevin Wood, he is your closest OOF Admin with Tech2  :y
« Reply #4 on: 28 August 2011, 18:49:03 »
Well, had a look on Friday and....
P1130 O2 Sensor 1, no activity
P0170 Lean Exhaust
P1325 (Not Present) Knock control limit Cylinder 3
Was certainly starting and idling OK from hot, and both Lambda sensors were cycling happily too. No excessive fuel trim  and the MAF was showing 8-10 kg/h at hot idle. A little lower than I'd expect, perhaps, but haven't tech2'ed that many 2.2s to form a solid opinion on that. All other live data looked plausible.
So, why the cold start problems?
<scratches head>
« Reply #5 on: 28 August 2011, 18:53:38 »
Blocked fuel filter?  :-/
« Reply #6 on: 28 August 2011, 19:55:38 »
Yes, that was one of the suggestions I made.  :y
Knock code and lean exhaust make me think it's going lean under load, and MAF doesn't look conclusively bad. Fuel filter is due a change so well worth doing to see if it clears the problem, IMHO.
« Reply #7 on: 28 August 2011, 22:37:39 »
worth a gander at the fuel filter, if its not too badly corroded see if its flowing right way. I found when I started working on mine rather than letter garages do it, the fuel filter had been mounted the wrong way around!  :o
Sehen
  • Norway, up north...
    • Omega???
« Reply #8 on: 29 August 2011, 23:05:38 »
Don't know about tech2, but can you see tha value of the coolant temp sensor on the tech2? Try to look at it when the engine is at ambient temperature, before you start it.
It should comply with temperatur in carcomputer as well as the intake air temperature, within a couple of degrees...
Had some experience with the tempsensor fail that did not produce a fault code regarding the tempsensor, but will f..k up the rest of the engine managment. If the ECU thinks it has an engine temperature of 95 degres Celsius when cold, it will certenly be hard to start :)
« Last Edit: 29 August 2011, 23:06:39 by Sehen »
98 Omega 2,5V6 Man. Homemade from a 2,0Auto
« Reply #9 on: 29 August 2011, 23:35:11 »
Didn't see the car from cold but the coolant temperature looked OK when warm. Another peek with a tech 2 when it's cold needs to be arranged if the problem persists, I think. :y
Sehen
    • Omega???
« Reply #10 on: 30 August 2011, 00:00:22 »
Did have a look at TIS, and they did mention a faulty connection at the plug to the coolant T.sensor. There is a retrofit sensor an plug kit with gold plated connectors.
It will produce hard starting an bad running with no codes to the coolant T. sensor.
Hope this will help a bit  :)
