Author Topic: Brake pedal travel  (Read 2376 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Brake pedal travel
« on: 30 August 2011, 13:10:45 »
Hi all,
Not having driven another Omega, I might be worrying over nothing. :(
My brake pedal travel is what I class as excessive. It seems to travel half way to the floor before anything happens. The brakes DO work, and ABS kicks in :y There is no fluid leak.
I have had the fluid changed, and had new discs and pads on the front and new pads on the back. The back discs are worn a bit, but no way critical. The brake pedal travel was the same before the work was done (which is why I had it done in the first place)
Also it did pass the MOT with no problems.
Is this normal...as in my Laguna Estate, the brakes work instantly.
Thanks in advance :y
Re: Brake pedal travel
« Reply #1 on: 30 August 2011, 13:32:02 »
IME pedal travel on the Omega is as you describe, and I've driven several ;)
When I got this one the fluid was 8 years old and I had really bad fade because I kept boiling the fluid ::) Once changed it was fine :y You've had that done and say the abs can be triggered so yours is probably fine too :y
« Reply #2 on: 30 August 2011, 13:38:06 »
Seems to be a characteristic of the car imo.Every one I have driven has more pedal travel then most other cars seem to have. :-/
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #3 on: 30 August 2011, 13:38:33 »
Thanks mate...
As I said, probably paranoid about nothing :y
Tony
the alarming man
  • medway kent
    • disco V8
« Reply #4 on: 30 August 2011, 13:49:56 »
 Hi terbert i am on my second omega now and yes that is correct...unlike my peugeot where the brakes failed on me this weekend >:(
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #5 on: 30 August 2011, 13:59:26 »
Hi Mark
Don't want to turn this into a discussion thread, but hope you are ok.
So basically, putting new discs on the back won't  make any difference....I'll save my money. ;)
the alarming man
  • medway kent
    • disco V8
« Reply #6 on: 30 August 2011, 14:03:59 »
would'nt have thought so...pads will if they are worn :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #7 on: 30 August 2011, 15:09:25 »
My omega had a soft pedal when I first got it,a fluid change and all new pads (rears were seized in calipers)and freeing off front  caliper slide pins made it much better
other rides
« Reply #8 on: 30 August 2011, 15:15:17 »
there is a lot of movement in the pedal, in motherT's other ride a Nissan Almera, a feather on the brake is like an emergency stop.
When she first drove Omegas, she thought the brakes were rubbish & did not work.
A couple of "quick" stops, showed they stop a 2ton car quite well  :D
« Reply #9 on: 30 August 2011, 16:38:29 »
They are a progressive brake pedal.
Most ther cars have an over assisted servo which makes brake progression non existant.
It does not however mean the brakes are poor as Omega brakes are not (infact if they are working well and you do an emergency stop, check the rear window!)
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #10 on: 30 August 2011, 17:16:36 »
Have you checked the brake servo vacuum pipe rubber connector? Mine was split and i replaced the rubber and have noticed slightly less brake travel. The connector is to the right of the brake fluid resevoir and a picture can be found here http://www.omegaowners.com/forum/YaBB.pl?num=1314489279/2#2
« Reply #11 on: 30 August 2011, 18:29:12 »
if you let the miggy rest for some weeks pedal travel can become "interesting" but must turn to normal quickly..
« Reply #12 on: 30 August 2011, 19:19:34 »
Its normal to have a fair amount of brake travel.
Next time you're up, pop it round, I'll tell you if its normal :y
« Reply #13 on: 30 August 2011, 19:24:08 »
Next time you're up, pop it round, I'll finish off your pads,warp your discs and shred your tyres. :y
Fixed that for you. :y :D
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #14 on: 30 August 2011, 20:13:09 »
Thanks Albs ;D ;D ;D ;D ;D
Ok Jamie, not up there again till kids back at school, but I'll pop round then on the off chance :y
« Last Edit: 30 August 2011, 20:14:04 by terbert1 »
Page created in 0.024 seconds with 16 queries.
