Author Topic: Errors P0130 and P0150 on Motronic 2.8.3  (Read 2241 times)
V6Astra F
  • Heidelberg , South Africa
  • 3.2 V6 Powered Kadett
« on: 02 July 2010, 19:01:15 »
Hi
These are the errors I get.
P0550 - Power Steering Voltage High   - Not Connected on my car-
 (01) - Present
P0130 - O2 Sensor 1 Open Circuit
 (04) - Not present
P0150 - O2 Sensor 2 Open Circuit
 (04) - Not present
Now the whole story :)
Ok I switched to a Motronic M2.8.3 from a Vectra( Had a 2.8.1 from a Omega). When Cruising at higway speeds the EML comes on when you lift of the throttle ever so slightly,if you put your foot down the light goes out. I have some live data from the ECU and I can see that both O2 Sensors go from Closed loop to Open :confused: and the mv readings drop to 0. I know these errors can be caused by faulty sensors, but I never had a EML light on the 2.8.1 ECU . Does the Omega use different O2 sensors than the Vectra ?
I also had a problem with the elbow that runs form the intake to the brake booster, it broke when the pipe was removed so all I could do was to use some Q Bond with the filling powder. Now im thinking maybe I have a vacuum leak on that elbow thats causing the errors to show up, or a leak on the exhaust system. We checked the wiring but could not find any problems.
Link to the live data file.
http://www.mediafire.com/file/mnmi2zjmlwi/Livedata_1998_Vectra-B_Engine__X 25 XE_201007021716.csv
Re: Errors P0130 and P0150 on Motronic 2.8.3
« Reply #1 on: 02 July 2010, 19:34:20 »
Try this link  :)http://www.mediafire.com/file/mnmi2zjmlwi/Livedata_1998_Vectra-B_Engine__X 25 XE_201007021716.csv
V6Astra F
« Reply #2 on: 04 July 2010, 19:28:06 »
Thanks for correcting the link  :y
I unplugged both sensors and the EML stays off , will do a road test tomorrow but this is realy strange since I would have tought the EML would come on if the sensors are not connected
V6Astra F
« Reply #3 on: 06 July 2010, 13:15:25 »
All I can think to try now is to replace the sensors and hope for the best  :-/
jamiro
« Reply #4 on: 31 August 2011, 04:05:46 »
Hi
 (01) - Present
 (04) - Not present
 (04) - Not present
Yeah you should place the sensor, I have similar problem like this in my car before :D
Page created in 0.008 seconds with 16 queries.
