Pages: 1 2 [3]  All   Go Down
Author Topic: help car not start  (Read 4464 times)
mick-1975
  • nottingham
Re: help car not start
« Reply #30 on: 31 August 2011, 12:21:03 »
checked round the filter all seems to be ok cant see anything out of place
« Reply #31 on: 31 August 2011, 12:26:50 »
Either put a jumper from ECU pin 3 to pin 2 or remove the fuel pump relay and bridge the two contacts with a short wire link with two spade connectors attached and get someone to crank engine while you listen for the pump. Failing that, apply 12v direct to the pump
« Reply #32 on: 31 August 2011, 12:40:09 »
Fuel pump easy enough to change on an estate. Cheap ish too, 'bout £50 iirc. :y
Being an auto, could it be the selector switch? :-/
And the rest :o
mick-1975
  • nottingham
« Reply #33 on: 31 August 2011, 12:41:44 »
ive ordered a crank sensor as people are telling me that it could be the problem .as someone a friend knows had the same problem and he changed the sensor so just got to wait for it to arrive in stock . i shall do as you say and try that .
 if not think it be towed to main deeler im affraid or scrap . as really doing me head in
« Reply #34 on: 31 August 2011, 12:44:42 »
Forget the crank sensor, you haven`t got a code for it and on the 2.2 a failed C/S will always throw a 0335. Put 12v direct to the pump. If it doesn`t run the pump is knackered. I`ve got a working one here if it`s donald
mick-1975
  • nottingham
« Reply #35 on: 31 August 2011, 13:01:09 »
do u know which wires are the earth and live as got full tank of fuel .
mick-1975
  • nottingham
« Reply #36 on: 31 August 2011, 19:03:07 »
  all done after changing fuel pump not another fault . see next post
Pages: 1 2 [3]  All   Go Up
