Pages: [1] 2 3  All   Go Down
Author Topic: help car not start  (Read 4463 times)
mick-1975
  • nottingham
help car not start
« on: 29 August 2011, 14:56:04 »
hi all ,hope you can help me . i went to work and car ran fine came to it after work and again started and ran great. Then while on the way home i lost all power and the car came to stop in middle of a island (not good )
  After looking at it i have found that there is no fuel getting through when i press the pressure release valve. The car will try and turn over but not start .
     The relays only make a noise once then nothing unless i take them out and back in again
    Fuel pump not buzzing when ignition switches on
 Any ideas of what this could be as im back at work later and going devon in 2 weeks .
 thanks alot . really need to get this sorted asap.. :y
Re: help car not start
« Reply #1 on: 29 August 2011, 15:12:02 »
Have you checked fuse #18 in cabin :question
Spanner light on :question
« Last Edit: 29 August 2011, 15:12:45 by RobG »
mick-1975
  • nottingham
« Reply #2 on: 29 August 2011, 15:16:41 »
spanner light did come on i checked them earlier but ill double check now for u
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #3 on: 29 August 2011, 15:16:41 »
if fuse fine would check the electrics plug above the tank, faling that motor may have gone.
Solar charger fitted.
If not Broke dont fix it..
mick-1975
  • nottingham
« Reply #4 on: 29 August 2011, 15:30:19 »
checked fuse all ok
 checked coonector above tank and all is good
 i have tried a test light to the pump to see if light comes on and its dead. do u know which one is the live wire as thinking off a direct feed from a battery to see if it works .
« Reply #5 on: 29 August 2011, 15:35:30 »
If the spanner light is staying on, need to get codes read, possibly an 0335. Any spark at the plugs :question No fuel, no spark = crank sensor
mick-1975
  • nottingham
« Reply #6 on: 29 August 2011, 15:39:14 »
got o obd2 tester from local shop and does not show crank sensor at all .
 can the crank sensor cause all this with fuel problems as well
« Reply #7 on: 29 August 2011, 15:54:21 »
Faulty crank sensor doesn't always throw a fault code.
Your fuel problems could be result of bad crank sensor - as RobG says above "No fuel, no spark = crank sensor" - check spark at plugs mate.
mick-1975
  • nottingham
« Reply #8 on: 29 August 2011, 15:59:23 »
ill check them now then and get back to u all
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #9 on: 29 August 2011, 16:00:17 »
had this problem on a 2.0 16v ecotec cavalier a few years ago.same symptons as your having,diagnosed as crank sensor,swopped it and away it went..:@)
mick-1975
  • nottingham
« Reply #10 on: 29 August 2011, 17:28:01 »
been back out and checked spark and guess what
  i have a spark at all 4 plugs .
  so what now ??
  NO FUEL.... BUT SPARK
« Last Edit: 29 August 2011, 17:30:25 by mick-1975 »
freecall666
« Reply #11 on: 29 August 2011, 17:51:37 »
check volts at pump if volts, then pump gone..
mick-1975
  • nottingham
« Reply #12 on: 29 August 2011, 19:13:16 »
tryed to use a test light and nothing not even a sound when ignition turned on .
  doing my head in as need it for work
« Reply #13 on: 29 August 2011, 19:39:07 »
Fuel pump easy enough to change on an estate. Cheap ish too, 'bout £50 iirc. :y
Being an auto, could it be the selector switch? :-/
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #14 on: 29 August 2011, 20:07:16 »
Fuel pump relay's are quite common failure items on Vx's, I think there the red/purple ones located under the bonnet.
Pages: [1] 2 3  All   Go Up
