Author Topic: 94 Elite 3.0 A/C pump smoking......  (Read 2938 times)
kentomega
  • Bromley
« on: 30 August 2011, 23:29:01 »
 :( Smoke has been pouring out of a pulley on the lower right front of my 94 V6 elite 3.0. A local garage says it's coming from the A/C pump, the clutch has probably seized. Apparently a new pump will be hundreds of pounds, but they can bypass the pump by fitting a shorter belt. Anyone know if this is true, and where I can get the right length belt?
Re: 94 Elite 3.0 A/C pump smoking......
« Reply #1 on: 30 August 2011, 23:32:45 »
I have a working pump that you can have for much,much less than that.  :y
Belt available from Vauxhall dealers - and possibly other places too.
You could possibly bypass the pump by using a shorter belt, but of course you will never have aircon again. ;)
I have sent you a personal message.It will say "you have 1 new message" at the top left of your screen.Click on that to view the message. :y
Welcome to OOF by the way. :y
« Last Edit: 30 August 2011, 23:44:38 by albitz »
kentomega
  • Bromley
« Reply #2 on: 30 August 2011, 23:38:36 »
Hi, thanks for the reply, I am in South London. Aircon would be good, especially as i only had it regassed three weeks ago!
But if it costs a couple of hundred labour to have another pump fitted, i think i will have to go without!
« Reply #3 on: 30 August 2011, 23:46:49 »
Wouldnt have thought it should cost that much, but Im sure others will know better than Im not sure if you lose the gas when you remove the pump. I suspect you will to be honest.
kentomega
  • Bromley
« Reply #4 on: 30 August 2011, 23:52:04 »
Hadn't thought of that! hat's another 50 quid then! ! have sent you a PM ...
« Reply #5 on: 30 August 2011, 23:54:42 »
And replied. :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 31 August 2011, 00:03:31 »
If the system still has gas in it find a friendly aircon specialist to vac the system and then fit new/second hand pump,return to said specialist and have the gas put back in possibly at a discounted rate as you won't have used much of his gas supply
other rides
amba
  • Medway towns
    • German V6
« Reply #7 on: 31 August 2011, 07:51:17 »
I had a local  A/C guy..(Istead Rise )..replace a compressor for me several years ago.
If I remember correctly it took about 1 hour to remove the old one and then replace,after he replaced the gas and did a total leak check.Its a bit of a pig of a job as access is limited and the top bolt requires wil need an extra set of hands to guide the extension bar down through engine bay but a specialits will have no real problems.
Drop me a PM if you want there details as I highly recommend them as have looked after my A/C needs for around 10 years and they are local to you.
« Reply #8 on: 31 August 2011, 19:15:24 »
Yep its true - you need an auxillary belt to suit an Omega 2 litre with A/Con - its the right length for the V6 without A/Con  :y
kentomega
  • Bromley
« Reply #9 on: 31 August 2011, 19:22:32 »
Thanks for all the tips, guys - I have contacted the aircon company at istead rise for a quote on fitting, and now I know which belt to go for, i'll soon have all the details I need to make a choice between bypassing or replacing! :y
