Author Topic: car missing on number 3 plug  (Read 2441 times)
Re: car missing on number 3 plug
« Reply #15 on: 02 September 2011, 13:25:34 »
Question is, how are you testing them as to do it correctly you need a large gap test plug to simulate the required 30-40mm gap.
If you work on a small gap you get no indication as to if the coil is ok and can also apply to low a load to it which may damage it.
Does the same apply to my issue on an X20XEV? I tried checking the sparks with a spark plug in the end of a HT lead and a jump lead from there to the battery negative.
Yes it applies to all and the test done is not a great test sadly.
Basics are that under compression, you need mega volts to create a spark in the cylidner, at atmpsheric pressure, to simulate this you need a big gap.
You could break down a 1mm spark gap with only 1KV at atmosperic pressures.
mick-1975
  • nottingham
« Reply #16 on: 03 September 2011, 14:36:13 »
Just to let you all know car all sorted now i changed the coil pack and it started and ticked over great . thanks for all your help on here . :y
