Author Topic: car missing on number 3 plug  (Read 2439 times)
mick-1975
  • nottingham
« on: 31 August 2011, 19:00:15 »
after all the grief about my last post that car wont start i have managed to sort it after changing fuel pump car started .but now missing badly . checked the plugs and number 3 not sparking .
   any ideas . please  :y
Re: car missing on number 3 plug
« Reply #1 on: 31 August 2011, 19:02:04 »
Compression (or lack of), duff plug, duff lead or dis pack.
mick-1975
  • nottingham
« Reply #2 on: 31 August 2011, 19:19:07 »
   was running ok before all the hassle with fuel pump .
 checked plugs and changed them all spark apart from no 3 .
« Reply #3 on: 31 August 2011, 19:20:22 »
Swap a sparking plug with the non sparker to eliminate coilpack
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #4 on: 31 August 2011, 19:29:13 »
more of a question really than an answer but my 2.2 has a coil pack which is all 4 in a row which sits over the plugs so if one coil goes down is it possible to replace just the one or do you need to get the whole shabang?
Warning: Dates in Calendar are closer than they appear.
« Reply #5 on: 31 August 2011, 19:35:12 »
You can buy replacement rubber boots and springs but the actual pack itself is an all in one jobbie
« Reply #6 on: 31 August 2011, 19:35:57 »
the whole lot I'm afraid.  ;) ;)
mick-1975
  • nottingham
« Reply #7 on: 31 August 2011, 19:39:52 »
i have tried 3 different plugs in the not working one also tried them in others so plugs are sparking but not on no 3 .
mrgreen
  • Salzburg/austria
« Reply #8 on: 31 August 2011, 20:00:59 »
oh when it rains it pours, when you had your fuel pump problem did you check for spark because if so maybe there's a chaffed wire leading up to the pack or bad connection, maybe a long shot but i would check the wiring before investing in a new coil pack
mick-1975
  • nottingham
« Reply #9 on: 31 August 2011, 23:32:10 »
before the problem i had a spark at all 4 as this was first thing i checked for . but know only on 3 of them .
« Reply #10 on: 01 September 2011, 13:11:14 »
Question is, how are you testing them as to do it correctly you need a large gap test plug to simulate the required 30-40mm gap.
If you work on a small gap you get no indication as to if the coil is ok and can also apply to low a load to it which may damage it.
mick-1975
  • nottingham
« Reply #11 on: 01 September 2011, 13:48:48 »
all sorted now car back up and running . Thanks to you
« Reply #12 on: 01 September 2011, 13:57:12 »
What was the problem?
Skint
« Reply #13 on: 01 September 2011, 17:55:23 »
Does the same apply to my issue on an X20XEV? I tried checking the sparks with a spark plug in the end of a HT lead and a jump lead from there to the battery negative.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #14 on: 02 September 2011, 13:22:23 »
can get spark plug,and lead tester for around £15. or old timing gun will work for few quid.
Solar charger fitted.
If not Broke dont fix it..
