Author Topic: car wont start, is it the crank sensor?  (Read 3090 times)
mr carl
« on: 01 September 2011, 19:02:42 »
i parked the car up at night, went to drive to work in the morning and the car is just turning over and over
at first i thought i could smell fuel while cranking the engine...but i loosened a spark plug (finger tight) and cranked the engine for a good 15-20 seconds and quickly whipped out the plug and it was dry as a bone
also i have no spark.
so what do you think?
crankshaft sensor or ecu? or maybe something else?
normally crankshaft sensors are a fairly hardy and simple bit of kit which never really tends to go wrong
also i unscrewed the sensor, and i cant find where the hell it plugs into, the wire is covered in heat proofing and ran up behind the blooming oil cooler pipes so i cant even wiggle the wire so someone else can grab it!
Re: car wont start, is it the crank sensor?
« Reply #1 on: 01 September 2011, 19:05:30 »
Classic crank sensor failure mate - do the pedal trick - bet you have a code 19.
Plug is up behind the plenum to the right of centre when standing at the front - whip the plenum off makes it easier to locate  :y
Abiton
« Reply #2 on: 01 September 2011, 19:06:32 »
Not on Omegas! Well, that's nto strictly true.  The sensors are great, but the cables aren't high-temperature enough for the way Vx routed them.
« Reply #3 on: 01 September 2011, 19:08:09 »
Yep reroute it to the right and down past the abs block  :y
mr carl
« Reply #4 on: 01 September 2011, 19:13:53 »
so its almost certainly the crank sensor then?
i have a spare 2.5 vectra one at hand, can i just cut the plug off and use this one for now?
blooming car, i have to drive my sister to her wedding next thursday i could really do without the hassle from the car atm, and i am moving, and its my sons birthday, and the car just decides to go nuts on me  ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #5 on: 01 September 2011, 19:25:09 »
Do the paperclip test  :y
If 19  comes up, its the crank sensor  :y
codes   http://www.omegaowners.com/forum/YaBB.pl?num=1160152416
paperclip test   http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #6 on: 01 September 2011, 19:34:06 »
Wouldn't recommend that mate - probably wont work  :)
mr carl
« Reply #7 on: 01 September 2011, 19:37:18 »
i was under the impression that the paperclip test would not work on the omega past 2000 plate?
Sehen
  • Norway, up north...
    • Omega???
« Reply #8 on: 01 September 2011, 19:42:52 »
If the plug is the same, it will work. for a while, becouse it does not have the heat protection. But for a emergency, that will work ok. Got mine from Saab dealer who had it in stock  :y
98 Omega 2,5V6 Man. Homemade from a 2,0Auto
« Reply #9 on: 01 September 2011, 19:43:23 »
No paperclip test will work ok on a 2.5 V6 lump :y
« Last Edit: 01 September 2011, 19:44:01 by dbug »
mr carl
« Reply #10 on: 01 September 2011, 19:45:51 »
the plug is square on the vectra one, and the plug is round on the omega one is it not? i have not had the pleasure of finding mine yet but the plug for my other sensors are oval
mr carl
« Reply #11 on: 01 September 2011, 19:47:03 »
could have worded that better my man, you mean it wont work on a v6 lump, or no, the paper clip test will work?
« Reply #12 on: 01 September 2011, 19:48:54 »
it will  :-? :-? :-?
mr carl
« Reply #13 on: 01 September 2011, 19:50:41 »
it will  :-? :-? :-?
sweet, but on my calibra if the engine was not running then the paper clip test would throw up the crank sensor even if the sensor was fine  ::)
Sehen
    • Omega???
« Reply #14 on: 01 September 2011, 19:57:03 »
The plug went from square to oval in either 96 1/2 or in the 98model year... correct mi if I'm wrong :)
