Author Topic: Dipstick tube won't budge.  (Read 1193 times)
Ewan
  • Near Dundee
« on: 30 August 2011, 10:37:49 »
Hi,
Is there a knack to getting this item out? After having removed the clamp at the top, I expected it would just pull out, but it won't. It turns round freely enough though.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Dipstick tube won't budge.
« Reply #1 on: 30 August 2011, 10:40:18 »
wiggle it and pull...
use rag and twist and pull....
Try them...
« Last Edit: 30 August 2011, 20:00:47 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 30 August 2011, 19:28:03 »
Yes, pull, but you have to overcome the seal, so it will be tight.
JasonH
« Reply #3 on: 30 August 2011, 19:48:00 »
Mine was unbelievably tight. I had to put a plank across the engine, tie a rope round the dipstick and use a crowbar pressing on the plank to pull mine out.
Apply pressure then wiggle and twist.
Ewan
  • Near Dundee
« Reply #4 on: 30 August 2011, 21:20:18 »
Thanks all, I just wanted to check there wasn't something arcane before the application of brute force.
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #5 on: 03 September 2011, 16:56:03 »
they often rust in - i have had to drill them out on V6's (engine out of car) be careful wiggling it as it can work harden and snap - hence drilling it out
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
