Author Topic: side trim clips  (Read 1652 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
side trim clips
« on: 02 September 2011, 22:02:34 »
Hi dose any one know what the part number is or were to get side trim clips, they fit in the trim square type about inchand half long, with round slip hole in them that fits to the metal studs in the rear part after wheel arch, they clip into the trim slide in to the trim and have 4 locks.... thanks
Solar charger fitted.
If not Broke dont fix it..
Re: side trim clips
« Reply #1 on: 02 September 2011, 22:10:14 »
Do you mean the white nylon/plastic clips that hold the side skirts/sill covers on :question
freecall666
Re: side trim clips
« Reply #2 on: 02 September 2011, 22:14:34 »
its the black bump side trim, fits on to metal pins welded to the skin, go's from wheel arch to rear lights. if helps have no camara to take a pic...
Re: side trim clips
« Reply #3 on: 02 September 2011, 22:16:13 »
Sorry mate, can`t help
freecall666
Re: side trim clips
« Reply #4 on: 02 September 2011, 23:16:20 »
its ok cannot find them any were looked on bay under all makes nothing that looks like them?? cannot even fix them as ends gone on the plastic locator.... and if get trim from scrapy they will just snap.. vauxhall said they could get them with a part number but no number on them.
twiglet
  • Norwich, Norfolk
Re: side trim clips
« Reply #5 on: 02 September 2011, 23:25:10 »
Speak to andyc on here. I bet he'll be able to find them for you.  :y
freecall666
Re: side trim clips
« Reply #6 on: 02 September 2011, 23:42:20 »
will do thanks :y
freecall666
Re: side trim clips
« Reply #7 on: 02 September 2011, 23:59:37 »
just thinking how do saloon one's fit on are they the same or sliders with screwed lock????
Clock
  • Liverpool
    • 2.6 V6 CDX Estate
Re: side trim clips
« Reply #8 on: 03 September 2011, 22:20:07 »
I presume all the trim is held on with these clips. I needed to replace the trim on the rear nearside panel above the bumper on my estate. I think the part number you want is 09 148 386.
If you pm with your e mail address I'll send you an image of it. How many do you need?  I'm sure i've got some left over
freecall666
Re: side trim clips
« Reply #9 on: 03 September 2011, 22:36:09 »
3 thanks, cool thanks.. :y
« Last Edit: 04 September 2011, 18:16:51 by freecall666 »
