Author Topic: Oil warning light takes a while to go out.  (Read 1424 times)
Agemo
  • Cleethorpes
  • Insignia
« on: 03 September 2011, 16:34:28 »
As title, recently started taking about four seconds when cold. There is no change in the sound as it goes out, so I don't think the engine is starved of oil.
I have recently changed the oil & filter, although I need the oil out soon to fit a Helicoil.
1/ Is is easy to remove the sender to fit a pressure gauge?
2/ Are the senders prone to breaking down?
3/ Are these senders the same across the range?
4/ Where are they on the TD
Thanks.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Oil warning light takes a while to go out.
« Reply #1 on: 03 September 2011, 21:41:06 »
take it out the sender and have a look, had one that was coked up and just clean'd it and worked ok after that also cleant the plug out and chaned the rubber seal.
Solar charger fitted.
If not Broke dont fix it..
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 03 September 2011, 22:54:47 »
Right, I will. Anyone know where it is located?  ::)
freecall666
« Reply #3 on: 04 September 2011, 14:12:44 »
bottom of engine about 4 to 5inches from bottom 2 wire plug. left side
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 04 September 2011, 15:19:01 »
brilliant - thanks - (It's the Turbo Weasel)  ::)
I suppose oil will pi55 out then.  :-/
« Last Edit: 04 September 2011, 15:20:31 by Agemo »
freecall666
« Reply #5 on: 04 September 2011, 16:46:25 »
yes if over filled lol but not a lot have a pan ready to catch it. if leave the filler cap on will not come out so fast. :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 04 September 2011, 19:38:21 »
OK mate, will have a look in the morning.  :y
