Author Topic: Omega wobble/judder while driving/breaking?  (Read 1831 times)
JJGSi24
« on: 08 August 2011, 21:22:02 »
Hi,i have an mv6 omega with this problem,when driving its ok at slow speeds but when you get up to 60-70 mph you can feel it,also when braking at this speed it judders,would i be right in saying its the front discs,they were replaced at 69k there's 82k on it now,any help appreciated,thanks in advance..
Re: Omega wobble/judder while driving/breaking?
« Reply #1 on: 08 August 2011, 21:26:56 »
Sounds more like a wheel balance issue to me ;)
tony2
  • peterlee north east
    • 2.6 cdx auto
« Reply #2 on: 08 August 2011, 21:27:17 »
hi JJGSi24 had same problem once changed discs/pads still same then changed front wishbones hey presto everything was then fine :y
« Reply #3 on: 08 August 2011, 21:29:12 »
I think you have two seperate problems.. first you need full geometry and also a check for wishbones..
warped discs also can cause judder when braking ..
so need a complete check imo..
google "WIM geometry center UK" they are well known here..
« Last Edit: 08 August 2011, 21:31:18 by cem_devecioglu »
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #4 on: 08 August 2011, 21:30:15 »
if it only wobbles without braking it could be your front wheels out of balance or possible steering component wear ?? may even be a warped disc ??
but these could also be felt whilst braking.
« Reply #5 on: 08 August 2011, 21:32:10 »
Yep... Could be wishbones but I'd start with the easiest/cheapest, the balancing ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 08 August 2011, 21:38:58 »
It's worth noting that rear wheel(s) out of balance will also give a judder.
I'd be inclined to pop down to a local MOT station and have the brake balance checked.  If you have seized or partially seized rear callipers then your front brakes are working overtime and will cause exaggerated wear.  :y
  • Auckland
    • Mazda MPV
« Reply #7 on: 08 August 2011, 21:44:06 »
Definitely front disks.
I fitted no-name disks to my last Omega. The 80mph vibration and juddering when braking became quite unpleasant after about 50k miles.
When I fitted new disks it was like having a new car :y
Worn wishbone bushes will probably make vibration and juddering worse but equally vibration and juddering will accelerate wear.
« Reply #8 on: 08 August 2011, 23:27:05 »
What discs where they? Vx discs will last more than 13k...?
JJGSi24
« Reply #9 on: 09 August 2011, 18:42:59 »
Thanks for the reply's,i'll go with getting the wheels balanced first and go from there..i'll let ye know how i get on. :y
Humpy
  • Tunbridge Wells, Kent
« Reply #10 on: 10 August 2011, 15:22:37 »
Dont forget the steering idler arm! I changed discs, pads and wishbones (all needed doing to be fair!) then changed the steering idler arm and the drag link. Still hasn't cured it completely (same symptons as you) but it's 99% better than it was...
Humpy
« Reply #11 on: 10 August 2011, 23:17:57 »
Ime...
Random wobble through steering, wishbone bushes failed
Vibration in a specific speed range, wheel balance preferably on a 5 stud balancer
Vibration when braking, fubar discs.
JJGSi24
« Reply #12 on: 06 September 2011, 20:53:57 »
I ended up changing both wishbones as the front bush on the pass side had split,i treated it to new discs and pads while i was at it,no wobble now,thanks again for the help/replies :y
tony2
    • 2.6 cdx auto
« Reply #13 on: 06 September 2011, 21:11:19 »
hiJJGSi24 glad you got it sorted you had same problem as mine which i said on 8aug you done same as me and now 2 migs running true :y
« Reply #14 on: 06 September 2011, 21:34:26 »
Thanks for feedback.  :y
