Author Topic: Bonet Vents for Lotus Carlton  (Read 1268 times)
rajveer.sandhu
« on: 08 September 2011, 21:38:19 »
Does anyone know where I can get bonnet vents (replicas) for a Lotus Carlton from?
I was thinking some vents on the Omega may make it look meaner, plus also help with cooling.
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: Bonet Vents for Lotus Carlton
« Reply #1 on: 08 September 2011, 22:00:01 »
readily available on the 'bay i believe
PM with your requests.
rajveer.sandhu
« Reply #2 on: 08 September 2011, 22:09:44 »
I have tried many different search criteria, still cant seem to get any results up.
twiglet
  • Norwich, Norfolk
« Reply #4 on: 09 September 2011, 00:33:56 »
http://www.ebay.co.uk/itm/Bonnet-Induction-Scoop-Vents-VHALL-CAVALIER-CARLTON-/260845724298?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbb9de28a
These are not lotus carlton vents, but would look equally as naff good as replica LC vents on an Omega.  :y
MV6Matt
  • London
    • No car since 2022....
« Reply #5 on: 09 September 2011, 08:09:49 »
I've thought abouth using them. Got some xjs tear drop ones but they didn't look like they where going to look right in the end. Neither did the LC ones.
I'm probably going to use Astra (?'G') ones when I get round to it.
You could ask http://www.coollouvres.com if they could copy the design and style and press into a bonnet?
I'll see what ABS have to say too.
HTH
Matthew :y
(thanks Ian)
andyc
  • Norfolk
« Reply #6 on: 09 September 2011, 12:02:53 »
Southwest Lotus have them in stock, or did but make sure your sitting down when you ask the price.
There orginal cost was around £80.00 to £90.00 quid each and thats just the outer grill not the fixing plate underneath
Cheers
Andy
Thetford. Norfolk
rajveer.sandhu
« Reply #7 on: 09 September 2011, 13:45:01 »
That is a lot.
I think they would make the car look better (aswell as other advantages).
May be if I can not source them at a reasonable price, then I should try some Escort Cosworth ones as there are loads of replicas about.
