Author Topic: Torque figures???  (Read 1117 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
Torque figures???
« on: 09 September 2011, 22:29:35 »
Hi, I have checked out the maintenance guides but can't find figures to fit the V6 clutch....
Can anyone give me the numbers for this? I just need the torque for the pressure plate to flywheel.
Thanks....
Re: Torque figures???
« Reply #1 on: 10 September 2011, 07:05:36 »
Haynes Book of 'dangle berries' says...
Torque wrench settings Nm lbf ft
Bleed screw . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 7
Hydraulic pipe union nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 10
Master cylinder retaining nuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 15
Pedal:
Mounting bracket bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 13
Pivot bolt nut . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 13
Pressure plate retaining bolts:
M7 bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 11
M8 bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 21
Release cylinder mounting bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 16
HockeyDave55
  • Milton Keynes
« Reply #2 on: 10 September 2011, 07:53:42 »
Thanks TB, I did forget one, the prop to gearbox....
On the Haynes book, I often wondered where they get their numbers from??? I work in engineering and do some testing that involves fixing torques, this includes applying a specific torque to a set of bolt, screws, nut or any combination of them, perform a test and check how the fixings are getting on.
We test move-on torque, this is always higher.
And back-off torque, this is always lower....
So, knowing this and not knowing how Haynes get their figures?????????
« Reply #3 on: 10 September 2011, 08:20:12 »
Haynes will get the info direct from GM ;)
« Reply #4 on: 10 September 2011, 08:22:00 »
Disc joint to propeller shaft transmission or differential:
Hexagon bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 95 70
Torx bolt*:
Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 37
Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tighten a further 75º
Stage 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tighten a further 15º
HockeyDave55
  • Milton Keynes
« Reply #5 on: 10 September 2011, 12:22:40 »
Oh ok, that makes sense...
Thanks for the numbers!  :y
