Author Topic: parts help  (Read 1162 times)
pirate
  • westhumble surrey
    • steinmetz elit estate
parts help
« on: 11 September 2011, 20:11:09 »
not got enough post yet .
im needing a mint auto leather gaitor for shift stick
mint gaitor for handbrake,
also two black plastic plugs that cover plenium cover bolts.
and on off side turn clip that holds the trim above headlight ,the plastic trim which runs accross eng bay above rad. this is on a pre face lift t reg elite steinmetz est
thanks folks
Re: parts help
« Reply #1 on: 11 September 2011, 20:19:23 »
thanks folks
I have the leather gearstick gaitor,although I dont think it can be taken off the gearstick without unpicking the stitching.
I have the handbrake gaitor.
Plenum cover plugs - dont have them.Everbody wants them when they are available.
If you mean the plastic turnclip at the outside edges of the rad cover panel ? I think I have a couple of those, but would have to check in the morning. :y
Re: parts help
« Reply #2 on: 11 September 2011, 20:22:38 »
thanks folks
I have :P :P............and yes, the stitching needs unpicking on the gaiter :y
Re: parts help
« Reply #3 on: 11 September 2011, 20:27:18 »
Never looked at how the gearshift lever comes off, but if its reasonably doable, I could just send the whole thing.Is it riveted on ?
Re: parts help
« Reply #4 on: 11 September 2011, 20:31:24 »
Cost a lot more to post than just the gaiter......................if you want the lever out, disconnect sprung clip under car at linkage, unplug connectors inside and drill the rivets out
Re: parts help
« Reply #5 on: 11 September 2011, 20:32:31 »
The gaitor is held on with a cable tie on an Astra if that's any use  ;) ;)
Re: parts help
« Reply #6 on: 11 September 2011, 20:34:37 »
Not on an Omega, unless a replacement has been fitted :P
Re: parts help
« Reply #7 on: 11 September 2011, 20:34:38 »
Probably easier for OP to restitch the gaitor than replace and rivet the gearstick. ;)
Re: parts help
« Reply #8 on: 11 September 2011, 20:35:54 »
As in Andy`s post re; Astra gaiters, replacements are usually held with a mini cable tie
