Pages: 1 [2] 3  All   Go Down
Author Topic: Changing a water pump  (Read 5326 times)
Re: Changing a water pump
« Reply #15 on: 10 September 2011, 12:31:57 »
andy, a quick one, why would my belt suddenly fly off the pullys as i was making a right turn, could it be the tensioner
Did it come off or shread itself? Could be your power steering pump slowing up when being asked to work hard with a full lock on  :-/ :-/ :-/ Was the belt on correctly in the first place? It's very easy to get the polly V belts a groove out between the various pullies.
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #16 on: 10 September 2011, 12:33:30 »
you wont do it any damage in a hundred yards, just take it easy
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #17 on: 10 September 2011, 12:36:36 »
belt is intact andy, just fell off,but it took the caseing with it, cant find that. thats when i noticed the water loss,
« Reply #18 on: 10 September 2011, 12:36:48 »
Its about 100 yards only problem is the water seems to come out quicker than I can fill it!!!
That's some leak!  :-?
Run your engine for the minimum amount of time that you can.  :y
« Reply #19 on: 10 September 2011, 12:38:04 »
The water pump casing?? Quuite a failure then!  :-?
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #20 on: 10 September 2011, 12:46:58 »
going out now to do it, fit new pump and put the belt back on for now and see what happens, cheers andy
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #21 on: 10 September 2011, 15:38:12 »
Be careful getting the three pump bolts out and putting them back in. It is easy to drop them inside the cam cover casing. A bit of grease on the bolt head helps.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #22 on: 10 September 2011, 15:53:40 »
Ok can I ash the maybe silly questions now.
I've removed the bagpipes etc and have access to the water pump? Is it simply a case of releaseing the aux belt and then unscrewing the pump remove refit and tighten or do I need to remove other components before moving onto the coolant flush and refill stage?
Again any advice greatly appreciated.
« Reply #23 on: 10 September 2011, 16:14:37 »
Remove the aux belt pulley from the pump to give more access to its bolts.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #24 on: 10 September 2011, 16:35:05 »
Its a bit tight should the plenum come off??
Varche
    • Golf Estate
« Reply #25 on: 10 September 2011, 17:12:52 »
No. Just put a (16mm?) ring spanner on the centre nut of the tensioner for the aux belt. The tensioner is top left looking from front. Then turn it and the whole tensioner swivels and the belt releases enough to pop it off. Perhaps useful to draw where it was routed first.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #26 on: 10 September 2011, 17:16:21 »
Thanks Varche
Like I said total novice... Probably should'nt even be trying to do this job LOL.. By the way the Waterpump is the big thing bottom centre isn't it (No I'm not joking)!!!
O
Varche
    • Golf Estate
« Reply #27 on: 10 September 2011, 17:27:05 »
Better to ask than have a problem. i felt embarrassed asking about how to do the ABS ECU a few years back.
We all started somewhere!! Better doing the job properly yourself than paying mega bucks at a garage.
Couple of other things. When you have the belt off just give the tensioner a quick spin by hand shouldn't sound noisy. They can be removed and repacked with grease. Second thing is if you have a new pump to fit when you have attached the body to the engine, next bit is putting the pulley on. Just check that the bolts don't foul the pump body by turning it by hand. Some pumps do. You will need to either fit shorter bolts or spacers like washersso the bolts don't stick out so much. Happened to me once with a QH pump.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #28 on: 10 September 2011, 17:40:15 »
Thanks for the advice.
Just yo make sure the water pump is behind the big pulley bottom centre!
« Reply #29 on: 11 September 2011, 16:34:58 »
Big pulley right at bottem centre is crank pulley - water pump pulley directly above it - only 3 bolts hold pully on and pulley smooth not grooved
Hope that clarifies :y
« Last Edit: 11 September 2011, 16:35:41 by dbug »
Pages: 1 [2] 3  All   Go Up
