Pages: [1] 2 3  All   Go Down
Author Topic: Changing a water pump  (Read 5155 times)
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« on: 10 September 2011, 11:05:06 »
Hi Guys
Quick question when changing a water pump do you have to remove the cam belt?
If not what does need removing
TIA
Re: Changing a water pump
« Reply #1 on: 10 September 2011, 11:16:03 »
Hi Guys
TIA
On a V6 no. The cam belt sit behind the belt cover while the aux belt (which drives the water pump) sits in front of the cam belt cover. I seem to remember it said the the cam belt cover can remain in place when removing the water pump but I'm sure I removed it when I did my water pump.
(obviously all the bag pipes/induction system needs to come off for access.  :y
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #2 on: 10 September 2011, 11:31:43 »
Thank Andy B
So its a job that can be done by a complete novice in a weekend?
 :D
« Reply #3 on: 10 September 2011, 11:36:28 »
Yep. :y
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #4 on: 10 September 2011, 11:38:01 »
Should it be a genuine vux water pump or are factored ones ok?
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #5 on: 10 September 2011, 12:08:35 »
if you can afford vauxhall prices then go for it,but i fitted a motor factors one @ about £62 and have had no problems with it  :y
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #6 on: 10 September 2011, 12:17:29 »
One final question how long can I run the engine without any water in the system?
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #7 on: 10 September 2011, 12:18:25 »
Thank Andy B
 :D
hi andy, im going to do a waterpump right now, £32 with the vat from gt autos preston. the car just threw the belt off,dont know why,but i noticed waterpump had started to leak
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #8 on: 10 September 2011, 12:20:23 »
dont, but if you must, 5 mins
« Reply #9 on: 10 September 2011, 12:20:39 »
Not very long at all. ie to move your car a few feet You'll bugger your engine if you run it for much longer.
Why do you want/need to run your engine without water/coolant?  :-? :-?
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #10 on: 10 September 2011, 12:21:47 »
I live in a very narrow cul-de-sac and the AA lorry had t drop the car off in a layby at the end of the road
« Reply #11 on: 10 September 2011, 12:22:19 »
5 mins is about 4.5 mins too long really  ::)
« Reply #12 on: 10 September 2011, 12:24:48 »
There must still be some water left in there  :-/ Just top it up with water for the short run. If the aux belt has already come off the pump or broken you'll still be better off with some water in the engine if you're just going to move the car.
« Last Edit: 10 September 2011, 12:27:44 by Andy_B »
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #13 on: 10 September 2011, 12:28:04 »
andy, a quick one, why would my belt suddenly fly off the pullys as i was making a right turn, could it be the tensioner
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #14 on: 10 September 2011, 12:29:01 »
Its about 100 yards only problem is the water seems to come out quicker than I can fill it!!!
Pages: [1] 2 3  All   Go Up
