Author Topic: Cannister type oil filter housing.  (Read 1283 times)
Mikes1670
  • Hull
« on: 12 September 2011, 17:05:03 »
Hi, does anyone know what size ring spanner I will need to remove the end cap of the cannister type oil filter housing? First oil change planned for this weekend.  :y
TIA
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Cannister type oil filter housing.
« Reply #1 on: 12 September 2011, 17:07:37 »
24
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 12 September 2011, 19:37:26 »
Let us know if it comes off ok can be a pita.
« Reply #3 on: 12 September 2011, 19:48:31 »
As Radar says, 24mm.  If a monkey previously did it, you may need something to stop the cannister turning.
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #4 on: 12 September 2011, 19:54:56 »
Sorry for the short reply earlier - i was in the middle of something at work. For "safety" (and as The Boy mentions) I had a banded filter wrench which i used to hold the main base just in case. Also i found that if you only partially unscrew the cap at first and let oil drip out it will make less mess on the underside of your car.
