Author Topic: Lambda Sensors  (Read 1195 times)
Nick27
  • London
    • Omega 2003
Lambda Sensors
« on: 12 September 2011, 15:35:48 »
Hi Guys,
Need help, where is the best place to buy  Lambda sensors for my F/L Omega 2003 2.2 Auto.
Appreciate your help guys!
Nick
Re: Lambda Sensors
« Reply #1 on: 12 September 2011, 15:42:37 »
What makes you think they have failed, are you using pattern cats? Got error codes? Emissions high?
Nick27
  • London
    • Omega 2003
Re: Lambda Sensors
« Reply #2 on: 12 September 2011, 16:19:22 »
Engine Management light was on when checked it gave Error code P0420, Catalyst effeciency below threshold Bank 1.
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
Re: Lambda Sensors
« Reply #3 on: 12 September 2011, 20:19:25 »
i had this problem earlier this year,had a warped exhaust manifold,changed that inc gasket,then turned out to be the cat that was knackered due to me running round with the eml on...!.check for any leaks in the exhaust/downpipe joint first though. :)
Re: Lambda Sensors
« Reply #4 on: 12 September 2011, 20:34:58 »
Very common occurence on the DBW engine ... reset the codes with a cheap reader and don't worry about it. :) It seems to occur if you change fuel supplier for some reason ... IME ... I bought the GS500 mainly for this reason ...  it is not a matter of "if" the 2.6/3.2 will give this problem .. but "when" ...  :)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Lambda Sensors
« Reply #5 on: 12 September 2011, 21:05:27 »
If you ignored a misfire for ages then I can see how a cat might fail, or if it was coated in oil maybe..
I think it's funny how you can 'scrap' a genuine cat and have enough cash to go a buy a brand new pattern part.
twiglet
  • Norwich, Norfolk
Re: Lambda Sensors
« Reply #6 on: 12 September 2011, 23:41:34 »
Am I being thick? The OP says he has a 2.2...
