Author Topic: Air con belt  (Read 1441 times)
BERN
  • Andover
Air con belt
« on: 13 September 2011, 18:29:48 »
My air condition pump has almost seized up[smoke coming from it].Is it possible to fit a shorter belt and by pass the pump so i can get back on the road,and if so would you know what the shorter belt length is.
Thanks
Bern
Re: Air con belt
« Reply #1 on: 13 September 2011, 18:51:05 »
Yes, it is possible. You need belt from non-aircon model :y
Re: Air con belt
« Reply #2 on: 13 September 2011, 18:59:30 »
Or a belt from a 2.0 Lit with aircon is the same length as the V6 non a/c belt  :y
Seems the 2 lit a/c belt is more readily available from Vx than a V6 non a/c belt!!
BERN
  • Andover
Re: Air con belt
« Reply #3 on: 13 September 2011, 19:31:48 »
Thanks for that,i will get a belt in the morning.
birdman
  • Chepstow
  • one volunteer is better than ten pressed men
    • 03 2.2petrol gls estate
Re: Air con belt
« Reply #4 on: 13 September 2011, 21:14:25 »
just done the same on my 2.2 petrol and used a hb1725g from Halfords,this is the size for a 2.0 w/o a/c ;)
Re: Air con belt
« Reply #5 on: 14 September 2011, 00:06:06 »
??? Ops got a 2.5 V6, not a 4 pot!! :-? :-?
