Author Topic: central locking  (Read 1434 times)
paintshoptec
  • cheadle, stoke - on -trent
    • 2002 cd v6 saloon
central locking
« on: 14 September 2011, 11:42:09 »
hi all
my central locking on the passenger front as stopped working correctly , it only moves slightly up or down when operated but it ok when you do it manually
does this mean it just needs a spot of oil or is it time for a change
thanks
Re: central locking
« Reply #1 on: 14 September 2011, 11:47:04 »
Possibly. Try something like chain lube that is 'sticky' & won't run off but is reasonably penetrating.
thanks
Probably.  :(
paintshoptec
    • 2002 cd v6 saloon
Re: central locking
« Reply #2 on: 14 September 2011, 11:51:45 »
been looking on ebay and there appears to be 2 types
for mine is this right
theres 2 part numbers  701 or 703
Re: central locking
« Reply #3 on: 14 September 2011, 11:55:27 »
No idea about part numbers but as far as I know, the fronts are both the same & the rears are both the same. And no difference between preface lift or face lift.
RobG will have a picture soon to confirm!  ::) ::) ::)
Re: central locking
« Reply #4 on: 14 September 2011, 11:59:05 »
RobG will have a picture soon to confirm::) ::) ::)
:P
Fronts are same on MFL & FL as are the rears. Pre-MFL are different. Pic of mfl/fl. Fronts end in 702, rears 703.
« Last Edit: 14 September 2011, 12:00:51 by RobG »
paintshoptec
    • 2002 cd v6 saloon
Re: central locking
« Reply #5 on: 14 September 2011, 12:05:48 »
thanks for your help
Re: central locking
« Reply #6 on: 14 September 2011, 12:08:28 »
Do you need a replacement :question
Re: central locking
« Reply #7 on: 14 September 2011, 12:08:46 »
They can be repaired cheaply and easily if you can use a soldering iron. http://www.omegaowners.com/forum/YaBB.pl?num=1275155915  :y
paintshoptec
    • 2002 cd v6 saloon
Re: central locking
« Reply #8 on: 14 September 2011, 12:23:23 »
going to have look on friday will let you know if i need 1 mate thanks
