Author Topic: Slow wipers  (Read 3328 times)
Squatch
  • Belfast
Slow wipers
« on: 14 September 2011, 11:20:50 »
Good morning everyone. I have noticed the wipers getting a bit slow and slightly juddery. Before I get the spanners out, does this sound like a failing wiper motor?
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
Re: Slow wipers
« Reply #1 on: 14 September 2011, 11:27:33 »
Judder would be down to worn wiper blades. Probably a good idea to get a replacement motor to have on stand by too.
Re: Slow wipers
« Reply #2 on: 14 September 2011, 11:29:08 »
Could be the linkages  :-/ There doesn't seem to be many recorded cases here of failed motors. The whole mechanism comes out reasonably easily - careful of your driver's sdie wing  :y
Squatch
  • Belfast
Re: Slow wipers
« Reply #3 on: 14 September 2011, 12:17:48 »
Thanks for advice! The blades are new so I will check the linkages. :y
Re: Slow wipers
« Reply #4 on: 14 September 2011, 12:20:56 »
Got a motor with linkage attached here if you need one. ;)
ambulance chaser mode off. Before RobG mentions it. :P ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Slow wipers
« Reply #5 on: 14 September 2011, 12:28:18 »
Pull the scuttle off and check the earth before you start ripping bits off  ;) ;)
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Slow wipers
« Reply #6 on: 14 September 2011, 12:37:38 »
Any idea how the battery condition is or how old? could be a sign of weak battery?  :y
Squatch
  • Belfast
Re: Slow wipers
« Reply #7 on: 14 September 2011, 14:10:09 »
Aye, true. The battery has given no problems as yet but then again, with the engine running would this affect wipers?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Slow wipers
« Reply #8 on: 14 September 2011, 14:21:30 »
no  ;)
Stallion
  • Romford
Re: Slow wipers
« Reply #9 on: 14 September 2011, 14:22:39 »
If the battery is weak, example you have the lights on the same time the wipers are also on, would be visible! an you mean engine running not while your driving?  :y
Stallion
  • Romford
Re: Slow wipers
« Reply #10 on: 14 September 2011, 14:24:02 »
no  ;)
Oh Yess!!! i had the problem thats why saying possible battery or alternator  ;) ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Slow wipers
« Reply #11 on: 14 September 2011, 14:29:47 »
no  ;)
No mention of starting problems / slow engine turnover in the op  ;)
Hence I would look at the wiper supply / earth first  ;)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: Slow wipers
« Reply #12 on: 14 September 2011, 14:35:29 »
I'd try the cheap and easy things first.  A squirt of cycle chain lubricant to the spindles and linkages.  If this makes a noticeable improvement, whip 'en out and do the clean and lube job properly when convenient.  And check the earth at the same time.
Worth checking voltages too, if you have a meter that really is good to 0.1V or better - cheap and easy again.
But I have Scottish ancestry  ;)
I feel like a military academy. Bits of me keep passing out.
Re: Slow wipers
« Reply #13 on: 14 September 2011, 14:38:47 »
Pretty sure there is no specific earth for the wiper motor.It is either earthed via the wring in its multi plug, or the motor body is the earth when attached to the chassis.I would suspect the former. ;)
Would agree about trying lubricating li kage though. Might just be a tad gummed up. :y
« Last Edit: 14 September 2011, 14:40:24 by albitz »
Stallion
  • Romford
Re: Slow wipers
« Reply #14 on: 14 September 2011, 14:44:17 »
no  ;)
True....  ;)
