Pages: 1 [2] 3  All   Go Down
Author Topic: ABS/TC lights  (Read 2650 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: ABS/TC lights
« Reply #15 on: 14 September 2011, 12:06:52 »
I would still get a code reader on it first,just because the sensors look ok doesn't mean they are.If a code reader isn't available use a multi meter on ohms setting and check resistance on each sensor. fronts will give different readings to rear depending on wire length but across each axle readings should be close :y
other rides
Re: ABS/TC lights
« Reply #16 on: 14 September 2011, 12:14:42 »
Got a code reader. Going to plug it in shortly and see what comes up. :y
Re: ABS/TC lights
« Reply #17 on: 14 September 2011, 13:06:23 »
Cant use the***** code reader. Interface not found. There is a procedure for getting it to work which involves repeatedly pressing F8 while doing something else at the same time. Cant remember the exact procedure.Various people have tried to install the software so it works as it should, but so far without success. :(
Re: ABS/TC lights
« Reply #18 on: 14 September 2011, 13:52:32 »
After some assistance via PM from a very helpful member, I have got the ***** reader working.
It told me the following.
Code C0045 -(8) Rear right wheel sensor incorrect signal - present.
C0045- (4) unknown DTC>not present.
Looks like it will be worth changing the rear right wheel sensor, before doing anything else. Anyone know if the rear right is right while sitting in the car ? would save the hassle of changing both and the possibility of further complicating the issue. :-/
Edit - theres a bit of oil mist from the diff around that area, might be worth cleaning that up before actually changing the sensor I suppose.
« Last Edit: 14 September 2011, 13:53:32 by albitz »
Re: ABS/TC lights
« Reply #19 on: 14 September 2011, 13:54:16 »
yes, always sat in the car.
If you set it recording live data, and drive a few yards, does it ever provide a signal?
maybe youve not plugged back in / trapped wiring by the diff?
Re: ABS/TC lights
« Reply #20 on: 14 September 2011, 14:00:10 »
Didnt want to venture into live data, bearing in mind the possibility for it to convert my engine ECU to think its  a diesel engine or similar. :D ;D
Checked the wiring plugs last night, they looked OK but will check them again shortly, then clean the serrated ring (oh err!) then if it isnt cured, swap the sensor for the one from my breaker.It does seem a bit too much of a coincidence that I was working in that area recently.Perhaps I inadvertantly stretched the wire to the sensor.I dont think so, but its possible. :-/
Re: ABS/TC lights
« Reply #21 on: 14 September 2011, 14:03:35 »
the ECU/Pump is an all in one jobbie, not a job i'd fancy doing, removed one on TB's Goldie, it already had half the engine components stripped out, still pig of a job!
No it ain`t :P
At the risk of stealing AndyB's quote.
<panto mode on>Ohhh yes it is!</panto mode off>
 ;D ;D ;D
Re: ABS/TC lights
« Reply #22 on: 14 September 2011, 14:08:56 »
The ECU does detach from the pump though. ;)
Anyway, this is probably all your fault.I could still be happily driving around with a broken spring, with working ABS/TC. :P ::) ;D
Re: ABS/TC lights
« Reply #23 on: 14 September 2011, 14:09:15 »
No it ain`t :P
 ;D ;D ;D
Actually.. You can unscrew the ECU from the front face of the valve block and leave the valves and pump in the car.
However, IME, once the ECU has failed it doesn't respond via the diag interface at all, so following up the wheel sensor code is a good plan.
« Last Edit: 14 September 2011, 14:09:40 by Kevin_Wood »
Re: ABS/TC lights
« Reply #24 on: 14 September 2011, 14:11:15 »
Thanks Kevin, it just gets better. :)
Re: ABS/TC lights
« Reply #25 on: 14 September 2011, 14:18:28 »
Did'nt know you could separate it, cheers  :y
Re: ABS/TC lights
« Reply #26 on: 14 September 2011, 14:19:57 »
Take my spring out, thats clearly the item at fault  ;D  :y
Just quick though, you did't trap/damage sensor/cable when doing the rear springs?  :-/
Re: ABS/TC lights
« Reply #27 on: 14 September 2011, 14:20:21 »
So I was right :P
Re: ABS/TC lights
« Reply #28 on: 14 September 2011, 14:20:49 »
So I was right :P
Maybe  ::)  :D
Re: ABS/TC lights
« Reply #29 on: 14 September 2011, 16:07:31 »
Did think of that. Inspected everything and no obvious damage.
Cleaned the sensor ring and the face of the sensor - still the same.
Just put a sensor on from my breaker and hey presto - all ok.
Took it for a drive,no lights showing.tested ABS and TC on loose surface. Both working fine. :)
Thanks for all the advice and info everyone.Much appreciated. :y
« Last Edit: 14 September 2011, 16:08:16 by albitz »
Pages: 1 [2] 3  All   Go Up
Page created in 0.024 seconds with 20 queries.
